Anti freeze leak :( - Mustang Evolution
Old 11-19-2012, 07:51 PM   #1
Jord05's Avatar
Anti freeze leak :(
So on my last ride with my stang she started running on 7 I got home parked it and found antifreeze in my 8th spark plug. Is that a head gasket leak or what could it be? Ps it's a new motor with only 15000kms I'm so mad right now I had money saved for performance parts and paint but now I feel like this could cost me. Any help would be appreciated thanks!!!
Jord05 is offline   Reply With Quote
Old 11-19-2012, 08:14 PM   #2
Rosco's Avatar
Unfortunately that sounds like a head gasket leak. Luckily if your partial to wrenching, a new set isn't very expensive and if you did the work yourself you could still tackle the mod list.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 11-19-2012, 08:18 PM   #3
Jord05's Avatar
I'm just more upset because its a new motor but does anyone have a guide on doing this step by step
Old 11-19-2012, 08:23 PM   #4
cliffyk's Avatar
You stated you "...found antifreeze in my 8th spark plug."?
Did you remove the plug and find coolant actually on the tip of the plug; or find coolant in the plug well?
Old 11-19-2012, 08:27 PM   #5
Inside the cylinder or on the outside
mymustang is offline   Reply With Quote
Old 11-19-2012, 08:27 PM   #6
Jord05's Avatar
In the well had to suck it out
Old 11-19-2012, 08:42 PM   #7
cliffyk's Avatar
The it not a blown head gasket, the intake manifold gasket is likely leaking, or the manifold is cracked. Just to be sure, cylinder #8 is on the driver's side near the firewall--is that the one in question?
I ask because it is not uncommon for the #4 plug well to fill up with coolant when the heater core nipple or hose is cracked, or if the clamp is bad...
Old 11-19-2012, 08:46 PM   #8
Jord05's Avatar
Passenger side closest to the fire wall
Old 11-19-2012, 08:52 PM   #9
Jord05's Avatar
So number 5
Old 11-19-2012, 08:58 PM   #10
cliffyk's Avatar
Number 4, check the heater core nipple and hose...
(the diagram is as seen from the driver's seat, those are the exhaust pipes, Où sensors, and catalytic converters shown below the block)
Old 11-19-2012, 09:03 PM   #11
Jord05's Avatar
Ok how do I check that
Old 11-19-2012, 09:19 PM   #12
cliffyk's Avatar
You look at it and see it if the nipple and/or hose are leaking. It is right by the #4 plug...
Old 11-19-2012, 09:22 PM   #13
Jord05's Avatar
How hard will it be to fix? Or expensive? Ill look at it this weekend when I go to the garage it's in
Old 11-19-2012, 09:26 PM   #14
cliffyk's Avatar
It depends on what is wrong with it. If the nipple is cracked there is no real solution other than replace the intake manifold, if the hose is cracked it might have to be replaced or cut-back a bit. Or it might just be that the clamp is loose, improperly installed, or not even there...
Old 11-19-2012, 09:28 PM   #15
Jord05's Avatar
If intake manifold is cracked ill be buyin the chrome one then. But I'll have to see if I can see the hose you are talking about thanks for all the help I hope I can figure it out
Old 11-19-2012, 09:34 PM   #16
1996mustang's Avatar
If its the farthest one on the passenger then its #7 cylinder and more than likely its the hose goin from the manifold to the heater. Its a usual thing that commonly breaks on the intake mani.
Old 11-19-2012, 09:36 PM   #17
cliffyk's Avatar
It's kind of buried in there, but it's the only hose coming vertically out of the intake manifold in that area.
The stock manifold performs as well as or better than any of the cheap rip-off aluminum manifolds available on eBay--so it you buy a shiny one get it from one of the name-brand aftermarket vendors.
You can get the FRPP PI intake from a number of online vendors for $240, with many offering free shipping...
Old 11-19-2012, 09:36 PM   #18
Jord05's Avatar
It's the one on the passenger side closest to the rear of the engine.
Old 11-19-2012, 09:37 PM   #19
I hope this image helps
Old 11-19-2012, 09:38 PM   #20
Btw dont ask its my brothers motor and he had the same problem deff not my motor lol
Old 11-19-2012, 09:45 PM   #21
Jord05's Avatar
http://www.americanmuscle.com/typhoo...-polished.html this one
---------- Post added at 10:45 PM ---------- Previous post was at 10:42 PM ----------
Looks like fun. Do you no if it was hard to fix at all or anything
Old 11-19-2012, 09:46 PM   #22
Intake manifold replacing in my opinion is a breeze. Just make sure nothing gets inside the heads while u have the intake off and ull be fine
Old 11-19-2012, 09:51 PM   #23
cliffyk's Avatar
Cylinders 1, 2, 3, and 4 (bank 1) are front-to-back on the passenger side; 5, 6, 7 and 8 (bank 2) are front-to-back on the driver's side--as in the diagram I posted above...
Old 11-19-2012, 10:04 PM   #24
Correct me if im wrong but im sure it 1357 pass side and 2468 driver side
---------- Post added at 12:03 AM ---------- Previous post was at 12:02 AM ----------
I stand corrected lol
---------- Post added at 12:04 AM ---------- Previous post was at 12:03 AM ----------
Was thinkin a totally diff motor probably chevy from work
-_-
Old 11-20-2012, 04:16 AM   #25
-_-
Ford diesel are numbered that way ,,but not gas
---------- Post added at 06:16 AM ---------- Previous post was at 06:13 AM ----------
Good call,,,all the ones we have at work,,(f250),,the aluminum part across the front where the thermostat located usually cracks where the plastic and aluminum meets
Old 11-20-2012, 05:58 AM   #26
cliffyk's Avatar
Mustangs generally fail on that end too, however I have seen a half-dozen or so where the heater core nipple has failed. Sometimes mechanically (perhaps damaged) and a couple where the plastic eroded.
The most common failure I have seen on Mustangs is that the inner wall of the formed seal retaining groove under the T-stat housing erodes and the seal pops out into the coolant passage, it then leaks through where the housing and manifold flange join.
Old 11-21-2012, 04:24 AM   #27
Thats exactly where the fail on the pick ups too,,matter of fact theres one in the shop now with the same problem,,You can get the whole intake and all pretty cheap at napa
Old 11-21-2012, 08:01 AM   #28
cliffyk's Avatar
Unfortunately the manifold sold by NAPA is a rebranded, universal fit, Dorman unit. One that I would not recommend for use on a Mustang unless it was something one needed NOW.
Belkamp manifold from NAPA:
Dorman manifold from Autozone:
Unless they have changed it recently it is basically a non-PI manifold (smaller lower plenum volume and old-style runners) modified to bolt up to the PI heads...
Old 11-21-2012, 04:29 PM   #29
Well i guess if he wanted to upgrade ,,i would go with something else,,but the one i have is just a regular truck ,,so it works fine
07:23 AM
