Power Door Locks - Mustang Evolution
Old 11-21-2012, 07:15 AM   #1
9tee7pony's Avatar
Power Door Locks
My car has the interior power door locks, but neither side works. All the other buttons do though. Also if I have those does it meat the car came with a key remote? I really haven't put much effort into figuring this out, but any help would be appreciated.
9tee7pony is offline   Reply With Quote
Old 11-21-2012, 07:30 AM   #2
IanM's Avatar
I'd check fuses, then the switch connections, and then maybe you'll have a better idea if it's a bad switch or something else.
IanM is offline   Reply With Quote
Old 11-21-2012, 09:55 AM   #3
9tee7pony's Avatar
It's not the fuse. For the switch connections would I have to take the door panel apart
Old 11-21-2012, 10:10 AM   #4
IanM's Avatar
That's probably the direction i'd head in then, you might have something as simple as a bad connection. It could have corrosion on the plug, a loose connection, or it may be a windows switch that's faulty. I'd take them apart and check, and make sure you check both sides before swapping out switches, as it might have a bad circuit causing the failure (one side being disconnected). You could try some CRC Contact cleaner spray on them even, it's designed for cleaning electrical connections and is safe to use on them. I know Advanced Auto Parts carries it, and most other places should as well.
01:30 PM
