Kenne bell debate - Mustang Evolution
Old 11-22-2012, 09:35 PM   #1
Matticus's Avatar
Kenne bell debate
I've seen numerous debates on the 6 psi non intercooled and the 9 psi intercooled twin screws. Some say the 6 psi is safe, others claim the heat soaking makes it not worth it. Would like some more knowledgable opinions before I make a decision. I know an inter cooler is always better, but the $1000 difference plays a big role too.
Matticus is offline   Reply With Quote
Old 11-23-2012, 07:56 AM   #2
WheelStander's Avatar
Do the 6 then intercool later.
Same blower.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 11-23-2012, 08:05 AM   #3
Eturner's Avatar
Same blower.
Or save for the extra cash and do it all at once!..
Old 11-23-2012, 08:08 AM   #4
Matticus's Avatar
Well just managing to get the non inter cooled one is gonna be a lot of saving lol
Old 11-23-2012, 08:31 AM   #5
Matticus's Avatar
I'm more or less concerned if the non intercooled one will function safely. I know it's a safe amount of boost, but will the heat be a big enough issue to cause problems?
Old 11-23-2012, 08:37 AM   #6
Las0mbra's Avatar
With that small of boost level you should have no problems with heat.
Old 11-23-2012, 09:17 AM   #7
Matticus's Avatar
That's what I thought too, but I've been told the twin screws soak a lot of heat, even sometimes when inter cooled.
Old 11-23-2012, 10:01 AM   #8
Rm360's Avatar
The KB case is made from billet aluminum which disperses heat so heat soak is at a minimum , if you run the 6 psi you will be ok but I would definitely get the inter cooler setup so you can run more boost and make more power, if you buy the non inter cooled kit and purchase the inter cooler later you will need a new tune also so the money you would save now will cost you more later , get the inter cooler setup and tune once and be done
Old 11-23-2012, 11:40 AM   #9
Matticus's Avatar
That 5k for just the kit though, that hurts my bank account lol
Old 11-23-2012, 12:41 PM   #10
Venomouz831's Avatar
Won't you rather be safe than sorry
)02 Gt, Founder of WE2G
Old 11-23-2012, 04:55 PM   #11
Matticus's Avatar
Yes, that's why I'm trying to do my homework before I buy anything lol
Old 11-24-2012, 10:56 AM   #12
Matticus's Avatar
Also, if I did save up for the intercooled kit that's at 9 psi, would I need to get forged internals? I know I wouldn't need it with the 6 psi one.
Old 11-24-2012, 11:18 AM   #13
No
---------- Post added at 01:18 PM ---------- Previous post was at 01:18 PM ----------
I'm gonna run 10 with stock internals.
Old 11-24-2012, 11:34 AM   #14
truckinu's Avatar
No
Don't mean to hijack, but at what psi would forged be necessary?
truckinu is offline   Reply With Quote
Old 11-24-2012, 11:44 AM   #15
Probably over 11 on a Gt engine with a 2.1.
Old 11-24-2012, 12:40 PM   #16
1996v6stang's Avatar
Jw what kinda miles yall have on ur stangs that u plan on scing.
1996v6stang is offline   Reply With Quote
Old 11-24-2012, 01:01 PM   #17
90k
Old 11-24-2012, 01:08 PM   #18
Matticus's Avatar
160k, but I'll be rebuilding the trans first.
Old 11-24-2012, 01:22 PM   #19
Has the motor been rebuilt ever?
Old 11-24-2012, 01:23 PM   #20
Matticus's Avatar
Not to my knowledge, but it's well taken care of and should cause any problems with a conservative tune.
---------- Post added at 02:23 PM ---------- Previous post was at 02:23 PM ----------
Shouldnt*
Old 11-26-2012, 07:58 PM   #21
CodyNelson's Avatar
Region: West Virgina
I'm running 12lbs on the stock bottom end right now in my GT. unfortunately though with these cars it's cheap, fast, reliable; pick two.
Old 11-27-2012, 02:29 AM   #22
Pick two....brilliant and accurate Cody.
Old 11-27-2012, 02:57 AM   #23
Lol
Old 03-13-2013, 01:10 PM   #24
Matticus's Avatar
Old thread, but I was looking around at more stuff again and found AM sells intercoolers for s/c or turbos. I know I'd have to get piping, but would that work in place of buying the intercooled kit from kenne bell? I'm almost positive I could come out a lot cheaper this way.
Old 03-13-2013, 01:24 PM   #25
The way I see it, Twin/Roots chargers are best used on heavy cars like the S197 that need more torque. A Centri/Turbo charger would be the optimum performer for your middle weight FOX4.
DieselStang is offline   Reply With Quote
Old 03-13-2013, 03:26 PM   #26
Here's what I did. Buying my KB in a few just doing everything else.
Afco dual pass HE, which is what you need for KB. Not a intercooler.
What you see cost me 200 bucks new.
ID:	95761   Click image for larger version
ID:	95763   Click image for larger version
Old 03-13-2013, 03:36 PM   #27
Matticus's Avatar
Where do you get that? That sounds like what I'm asking for
Old 03-13-2013, 03:44 PM   #28
Streetside.com
---------- Post added at 05:44 PM ---------- Previous post was at 05:44 PM ----------
I made the bracket
Old 03-13-2013, 03:47 PM   #29
Matticus's Avatar
So with this HE, you don't need the intercooled kit?
Old 03-13-2013, 04:29 PM   #30
Yeah you do you just don't need the HE. You get credit for that at KB. You still need the pump and reservoir or do your own.
The Afco is the best for our application and use.
---------- Post added at 06:29 PM ---------- Previous post was at 06:27 PM ----------
It's like boost a pump, KB sells it but it is junk.
I did it the right way and put dual cobra pumps on for 200 bucks.
05:04 AM
