Sharing a tuner - Mustang Evolution
Old 11-23-2012, 02:10 PM   #1
1996v6stang's Avatar
Sharing a tuner
Me and my buddy have the same cars just 5 speed and auto are the only diff. Can we buy a tuner and use it for both of our cars?
1996v6stang is offline   Reply With Quote
Old 11-23-2012, 02:17 PM   #2
deadsp0t's Avatar
Nope, you'll have to return your tune to stock to load a tune to his.
That's unimpressive
Old 11-23-2012, 03:15 PM   #3
Damn that sucks thanks
Old 11-23-2012, 03:19 PM   #4
Venomouz831's Avatar
Nope
)02 Gt, Founder of WE2G
Old 11-23-2012, 07:16 PM   #5
What all can i do with a tuner?
Old 11-23-2012, 11:01 PM   #6
2002VertGT's Avatar
You can change the tune to a more aggressive tune to give the car more power. You can change the shift points in a auto to make it shift more aggressive. You can get the most hp out of your mods. If you change gear ratio or tire size you can set it so your speedo is right. You can change the temp at which your cars fan turns on. Lots of stuff...
4.10 Gear/RPM thread
Old 11-23-2012, 11:09 PM   #7
Is there a post where i can learn more about them?
Old 11-23-2012, 11:13 PM   #8
2002VertGT's Avatar
Have you tried sct's website? You can also search the forum for sct or tuner
Old 11-24-2012, 12:32 AM   #9
If i put o/r pipes on my car can i block out the o2 sensor code?
Old 11-24-2012, 02:06 AM   #10
Black99Snake's Avatar
the only tuner that you can do that with really is the sniper delta force software. its a program you install on your pc/laptop. you can tune multiple vehicles with it. i use it and so does a good friend of mine. its very in depth tuning much like a tuner would use at a tuning shop. you would want the cammando.
Delta Force Tuning - Complete Automotive Ford tuning products and programmers
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 11-24-2012, 02:13 AM   #11
Sounds good but i dont even have a computer
Old 11-24-2012, 05:07 AM   #12
2002VertGT's Avatar
Yes you can you just can't do it from the hand held you just tell them when you order the tune and they will shut them off
Old 11-24-2012, 06:58 AM   #13
Im not sure about the older ones,,but mine which is a 06 i can turn off the back o2s,,if I dont want to run cats ,,or high flows
mymustang is offline   Reply With Quote
Old 11-24-2012, 11:50 AM   #14
I was talking to my dad and he is worried that will cause problems if put an o/r kit on my car and shut the o2 sensors off.
Old 11-24-2012, 12:04 PM   #15
Eturner's Avatar
Zero problems with that dude!... I've been running like that for four years and mine is a DD!...
---------- Post added at 02:04 PM ---------- Previous post was at 02:04 PM ----------
Mine is a '04 GT!..
Old 11-24-2012, 12:06 PM   #16
Las0mbra's Avatar
The o2s you're shutting off are the rear ones. The rears are just to make sure the cats work. The front ones are left on because they are before the cats/or xpipe and they measure stuff to keep the engine running well.
Old 11-24-2012, 12:14 PM   #17
Thats good to hear cause mines a dd aswell.
10:54 AM
