Tach wire - Mustang Evolution
Old 11-24-2012, 08:43 PM   #1
Poopyhead44's Avatar
Tach wire
I have a 2000 gt does any one know what color the wire that comes out of the CPU reads the rpm? I'm trying to wire a window switch
Poopyhead44 is offline   Reply With Quote
Old 11-24-2012, 09:19 PM   #2
Coreyw428's Avatar
Region: Arkansas
Only way to get a tach on 99 up is through a tach adaptor... They have them on American muscle..
Coreyw428 is offline   Reply With Quote
Old 11-25-2012, 11:41 AM   #3
cliffyk's Avatar
^+1, there is no conventional tach signal produced by the PCM. The instrument cluster tach is driven via digital data delivered over the SCP (OBD2) data bus...
Old 11-25-2012, 12:42 PM   #4
I've. Been reading and a lot of people say you can tap into a coil wire the red and white one on the #8 coil
Old 11-25-2012, 01:58 PM   #5
Coreyw428's Avatar
Region: Arkansas
There might be another way to, just have to do some research, I know I've always been told on coil pack and cop cars you have to use the adaptor to get a rpm signal
Old 11-25-2012, 03:40 PM   #6
cliffyk's Avatar
You can if the device you are connecting to can deal with that signal, and can be adjusted to handle a 2 revs/pulse input (any single cylinder only fires once per two engine revolutions on a 4 stroke/cycle engine).
Another complication that some tach-like devices can't handle is that at idle, and up to 1200 rpm, each COP fires rapidly three times at each spark event, as shown below:
This is to improve combustion and emissions at idle and low engine speeds. It can confuse some external devices if they do not filter out the repeat firings.
Old 11-25-2012, 06:59 PM   #7
You seem to be very knowledgable about this so I'm gonna go ahead and order that tach adapter thanks for the imput
12:15 AM
