Possible oil leak - Mustang Evolution
Old 11-25-2012, 04:42 PM   #1
1lowGT's Avatar
Possible oil leak
I was under my car looking at my exhaust and I seen oil all around the oil pan looks like there is no oil above the oil pan looks like I might need a new gasket? I tried tightening the bolts but the wouldn't budge. I will post pictures below. See what you guys think
Old 11-25-2012, 04:50 PM   #2
schmitty426's Avatar
Did u just recently get your oil changed? Sometimes those so called "professionals" are messy
schmitty426 is offline   Reply With Quote
Old 11-25-2012, 04:50 PM   #3
Be careful, you can overtighten the bolts. If you are going to do the gasket make sure you have enough room to fully remove the oil pan from the car to properly clean the surface.
Old 11-25-2012, 04:52 PM   #4
1lowGT's Avatar
Old 11-25-2012, 04:56 PM   #5
1lowGT's Avatar
No I change it myself
---------- Post added at 05:56 PM ---------- Previous post was at 05:52 PM ----------
Yeah I didn't try to hard but the didnt move. Yeah I'll try to get a new gasket this week. So ill drain the oil then drop the pan clean it and the area around. But look at the pictures I just posted there is a lot around close to the filter maybe it's just not right enough but I don't have any oil dripping its just around the gasket and filter. Ill have to check it out. Car will be shopped for a few weeks basketball starts this week won't have much time. And I'm in highschool lol.
Old 11-26-2012, 10:47 AM   #6
1lowGT's Avatar
Anyone else??
Old 11-26-2012, 11:17 AM   #7
Mile high JDF's Avatar
It's only leaking on the drivers side of the engine? I would double check the tightness of your oil filter. It's possible that your oil filter gasket didn't seat right.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-26-2012, 01:48 PM   #8
1996mustang's Avatar
I would check the oil filter housing. Have the car running while its jacked up to see if its leaking from the housing could be what happened to me i changed the oil pan gasket to find out later it was the oil cooler gasket -_-
Old 11-26-2012, 02:36 PM   #9
1lowGT's Avatar
It's all the way around I think I'll check it out more Wednesday.
---------- Post added at 03:36 PM ---------- Previous post was at 03:35 PM ----------
Ill try that and it's not really leaking and dripping on the floor it's jut oily around the thing but there are some oil puddles around a few bolts but it's really oily around by the filter
Old 11-26-2012, 03:57 PM   #10
One thing you can try is get a couple cans of brake cleaner from autozone and clean all the oil off really good. After that have buddy turn the engine on and hold the rpms at about 2000 while you look at the oil pan from underneath
Old 11-26-2012, 08:36 PM   #11
1lowGT's Avatar
Alrighty ill try that thanks
Old 01-12-2013, 07:11 AM   #12
1lowGT's Avatar
Sorry for bring this back but should I drain the oil then clean off the oil spots then put more in?
Old 01-12-2013, 07:37 AM   #13
What do u mean? Clean the bottom off leave the oil inside the car and make sure u have enough oil then like he said have someone hold it at 2k rpm while u search for the leak. It will more than likely be by the oil cooler.
Old 01-12-2013, 07:40 AM   #14
1lowGT's Avatar
Well I'm gonna change my oil today so I wonder if I should clean it and check it before I change it
Old 01-12-2013, 10:54 AM   #15
Ok well if u plan on an oil change i would see if u can find it first. It would suck if u change the oil then clean under the car and then find out its something like the oil cooler or filter housing cause then u have to drain out all the oil again to replace it.
Old 01-12-2013, 11:59 AM   #16
lee1rbc's Avatar
Yeah, you really need to clean everything after your oil change and check it again in a couple days. You are showing alot of oil around the filter and oil doesnt travel uphill, im guessing your fine just left over oil from the last oil change probably puddled on the rack n pinion and then made a mess over time.
2001 SVT Cobra 04 Mach 1 motor & trans, 01 Cobra cams, bassani x, flowmaster catbck, JLT CAI, 4.11 gears, Tokico D-specs, eibach springs.
lee1rbc is offline   Reply With Quote
Old 01-12-2013, 05:35 PM   #17
1lowGT's Avatar
Well it's kinda a mess I think I'll just take it to the shop and have them look at it.
11:07 PM
