I never had but I've only had the car for about 1500 miles. The guy who had it before me took good care of the car so it's not unreasonable to think he had changed them before but I don't know for sure if he ever did.
Mine just got coolent in that spark plug and exact same problem . So check ur plug first takes 5 mins and you will be able to tell right away! You can check my thread I have about it if you want
Hey just a warning, when changing the spark plugs on these cars there is a very specific way to doing them or you can cause some bad damage. They're notorious for spark plugs to blow out of the head.
I changed the plug. There wasn't any fluid or anything around it. Put it all back together,it started fine but still sounded like it was misfiring. Pulled the coil off while it was running and nothing happened. Ideas? Prolly the coil but I've also head where it could be a clogged fuel injector.
80 percent of the time its the cop. Very unlikely to be a fuel injector. More likely to be a bad valve then that. I would change the coil and i almost 100% guarantee problem solved.
No wiring brand is up to you motocraft will work just fine
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
