Hissing sound - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Old 11-30-2012, 05:12 PM   #1
MineralGrayGT's Avatar
MineralGrayGT is unknown around these parts
Hissing sound
So i have a 02 GT and when i start the car at idle there's a very loud hissing sound but when i hit the peddle just to rev it a bit it goes away then comes back at idle. Any ideas on what it may be im assuming a vacuum leak? Or any ideas on how to check it
MineralGrayGT is online now   Reply With Quote
Old 11-30-2012, 05:16 PM   #2
lowflyn is unknown around these parts
Do you have a cai?
Old 11-30-2012, 05:17 PM   #3
1shotkllz's Avatar
1shotkllz is unknown around these parts
Probably a vacuum leak, pop the hood and while it's running and see if you can't pinpoint the noise. Have any problems while driving? Like hesitations, stalling?
1shotkllz is offline   Reply With Quote
Old 11-30-2012, 05:18 PM   #4
No, car is all stock nothings been done to it
---------- Post added at 05:18 PM ---------- Previous post was at 05:18 PM ----------
No problems driving or anything
Old 11-30-2012, 05:46 PM   #5
1shotkllz's Avatar
All I can say is trace the noise, that's really the only way you're going to find out if it's a vacuum hose, or something else.
I know with my cai you can hear it sucking air at idle, but on rev up it turns into a "wooosh" noise. Time to get your hands dirty, so to speak, and find it.
Old 11-30-2012, 08:51 PM   #6
1996mustang's Avatar
1996mustang is unknown around these parts
Use carburator cleaner....spray a light mist about 9 inches away from vacuum lines and such and listen to rpm raise up. It usually leads u in the right direction to pinpoint the problem
Old 11-30-2012, 10:09 PM   #7
1slosix's Avatar
1slosix is just getting started.
i do this at work all the time to hunt down peoples leaks
carving corners like a boss
Eibach Strut Tower Brace - Rear Shock Tower Brace - GT Rear Sway - Goodridge Gstop SS lines - SR Performance Springs - Sensa-trac Shocks - Mac Prochamber - Borla Stinger 2.5" Mandrel Catback - K&N - Torqthrust Wheels wrapped in Kumo's - TB Spacer - HIDs & Other Visual Goodies
Old 11-30-2012, 10:11 PM   #8
Same here saves time on alot of jobs
08:40 PM
