New to nitrous - Mustang Evolution
Old 12-01-2012, 06:05 AM   #1
Poopyhead44's Avatar
New to nitrous
Ok I traded out some stuff and ended up with a wet nitrous system. It came with a bottle heater and I see they sell a bottle thermostat. Should i put the heater on a separate switch or should I wire a thermostat thru the arming switch? What is optimum pressure?
Poopyhead44 is offline   Reply With Quote
Old 12-01-2012, 10:36 AM   #2
Bump
Old 12-01-2012, 11:38 AM   #3
Mathew r Wright's Avatar
You can use arming switch, but you only need the bottle heater a few min because 900-1000psi is optimum pressure. If bottle heater raises more than that then it can be dangerous. Make sure have everything even the inline fuse before the relay, other wise you'll go through them... Anything else just let me know...
Mathew r Wright is offline   Reply With Quote
Old 12-01-2012, 12:01 PM   #4
So what would I need a thermostat for? Couldn't I run a separate switch and just watch the in cab pressure gauge? I just don't see a reason for a thermostat
Old 12-01-2012, 08:43 PM   #5
Oh shoot I'm sorry man, no a thermostat in not absolutely necessary, but I would not do the heater to the arming switch, you just don't need the heater all the time...
Old 12-02-2012, 06:42 AM   #6
I did some research to learn how the thermostat works I guess it will get your bottle to 85 degrees ( 950 psi) and switch on and off to hold it there. Some thermostats are adjustable I not sure which one. I also found that people debate pressure switch vs thermostat so I'm still scratching my head. I think no matter which way I go I'm still going to use a master arming switch for the heater only
. I should mention this is a street application my other concern is my black car sitting in the hot nc sun is it possible for it to get to hot and build to much pressure?
Old 12-02-2012, 09:53 AM   #7
Yah I just use a pressure switch because I don't use mine very often at all. Just got it couple months ago and it was fun beating a turbo civic but I really don't use it that often so I use a pressure switch. If pressure isn't @ least 900 then it's a no go till it is.... And as far as the winter months go you don't really have to worry about it sitting in the sun. The summer is different story. But don't worry your car won't blow up. All nitro bottles have a pressure release in the neck of the valve that will let off pressure if it gets to high. Then u just lose your nitrous. I would invest a blowdown tube if you are worried about the pressure under the sun. Plus you'll need it if you ever go to the track with it...
Old 12-02-2012, 11:06 AM   #8
Thats funny I have a turbo civic in mind! how much are you spraying?
Old 12-02-2012, 12:20 PM   #9
125 @ the time and I barely beat him too. I really don't know how I did neither. But I'm back down to 100 now...
Old 12-03-2012, 08:34 PM   #10
1996v6stang's Avatar
Are u stock pushin that?
1996v6stang is offline   Reply With Quote
Old 12-03-2012, 10:42 PM   #11
Ya
Old 12-03-2012, 10:47 PM   #12
Completely stock? What mods do you have?
Old 12-03-2012, 11:23 PM   #13
Ah just a cold air intake and x-pipe mid pipe with colder plugs a lil timing ****** for 125 shot just two degrees if I remember tuner saying... Made 352/407(100) & 397/443(125)...
Old 12-04-2012, 06:19 AM   #14
Nice! I been thinkin bout gettin a system.
Old 12-04-2012, 06:58 AM   #15
Just a chemical supercharger man it's fun. And super easy so don't discourage it...
Old 12-04-2012, 08:51 AM   #16
HAha just never race him again and you can always talk shiz
nitrous
10:31 AM
