Dropping the k member/removal of header studs - Mustang Evolution
Old 12-01-2012, 07:15 PM   #1
1996v6stang's Avatar
Hat all do i need to do. What needs to be dis connected. How many bolts to drop it. Do i needa take the springs and **** out? Whats the easiest and most cautious way to remove the header studs.
1996v6stang is offline   Reply With Quote
Old 12-01-2012, 07:53 PM   #2
You can do manifolds without dropping the k member
Old 12-01-2012, 07:59 PM   #3
Venomouz831's Avatar
You're installing longtubes aren't you?
)02 Gt, Founder of WE2G
Old 12-01-2012, 08:11 PM   #4
Yeah lts
Old 12-01-2012, 08:22 PM   #5
Any help would be nice. Im doin this tomorrow.
Old 12-02-2012, 10:48 AM   #6
If you insist on dropping the k member you will need to remove springs, brakes, struts and steering.rack. Support motor and unbolt the k member from both the chassis and the motor. It will then just drop right out of the way.
Old 12-02-2012, 07:40 PM   #7
Just a heads up lts are a ***** and not all the bolts can be used. You will need to re use some of the stock studs. I wont advise anyone to do lt installs them selves. Hopefully ill be done in a couple days. Since i didnt get it done before work tomorrow. And mind you all i have a lift. It seems like this would be impossible without. But this is my first time so im learning the dos and donts. On the brighter side i have my magna packs on order.
06:54 PM
