P.A.T.S issue - Mustang Evolution
Old 12-02-2012, 11:26 AM   #1
P.A.T.S issue
i have a 96 gt ,theft light is flashing ,car wont start....called locksmith ,he reprogramed keys ,cut new keys..i changed the computer nothing worked......i just ordered a sniper tuner ,wont be here untill later this week ,it has the option to disable pats..will this work?? or does any one have any suggrstions ..im new here to the site any help would be greatly apprecciated thanks
lgw8471 is offline   Reply With Quote
Old 12-02-2012, 12:15 PM   #2
1996mustang's Avatar
Did u by any chance do anything by the lock key cylinder?
Old 12-02-2012, 12:19 PM   #3
the ignition switch?
Old 12-02-2012, 12:28 PM   #4
ignition switch was changed on it recently
Old 12-02-2012, 05:30 PM   #5
there is the issue then i believe, when u changed the ignition switch did it begin then? if so u probably broke this part for the pats. i posted up a link for its picture and name of it.
http://img801.imageshack.us/img801/14/img5913b.jpg
they call it a pats halo, ive been looking for a proper name but no luck on that but thats the jist of the thing, if u broke any parts of the halo it will not start the car, even a hairline crack ruptures the wiring in it that provides the resistance or communication to let u start the car up.
Old 12-03-2012, 08:24 AM   #6
it was running after i had it changed so not sure if that would be the issue
Old 12-04-2012, 03:01 PM   #7
Cali Stang's Avatar
I'm just curious, when you stated the car doesn't start, does the engine at least turn over or do you just get nothing?
Cali Stang is offline   Reply With Quote
Old 12-04-2012, 05:38 PM   #8
sorry the car does turn over but no fuel or no spark....hot wired the fuel pump and it is working security light flashing fast!!!!
Old 12-04-2012, 05:58 PM   #9
Cali Stang's Avatar
Well, that's a way to get it going. Hope it works out.
Old 12-04-2012, 07:30 PM   #10
Well fuel pumps working hot wired only ........but the coils aren't delivering the spark the security light is still on an flashing .....tuner will. Be here Thursday to delete pats I will keep y'all updated if it. Works its well worht i t if it does
---------- Post added at 08:30 PM ---------- Previous post was at 08:28 PM ----------
Still not running yet but the tuner should work !!!
09:15 PM
