IRS Swap - Mustang Evolution
Old 12-02-2012, 12:55 PM   #1
buickregal79's Avatar
IRS Swap
So i was thinking of doing a IRS swap into my 01 GT i was wondering if there's a write up on it and if its really worth the work and money? Thanks everyone!
Shutting off the thought process is not rejuvenating; the mind is like a car battery - it recharges by running.
buickregal79 is offline   Reply With Quote
Old 12-02-2012, 01:05 PM   #2
Everything bolts right up, only decision is whether to change the u joint on the driveshaft or the pinion flange on the diff.
You will need the irs assembly with all hardware and brackets. Irs springs and shocks.
Old 12-02-2012, 01:24 PM   #3
Venomouz831's Avatar
Yea easy bolt on just straight up
)02 Gt, Founder of WE2G
Old 12-02-2012, 02:10 PM   #4
Lorraine's driver
ab_mach1's Avatar
Stock for stock, can an IRS hook up better than the 8.8 SRA?
Instagram: @ab_mach1
Old 12-02-2012, 04:38 PM   #5
As far as drag racing? The halfshafts is the weakness, they don't take much of a launch to break
Old 12-02-2012, 06:05 PM   #6
Lorraine's driver
ab_mach1's Avatar
I've seen a few IRS swaps on Mach 1's. I'm wondering why. I think the Mach's were kinda setup to run the quarter more so the GT's. Maybe it's Cobra envy, Lol.
Old 12-02-2012, 06:56 PM   #7
Are they worth the swap and time and money? Do they handle better? I don't plan on drag racing more autocross style racing.
Old 12-02-2012, 07:42 PM   #8
Well, you will be adding right at 300lbs to your car and honestly a sra can handle better than ford's version of irs. If I was building a irs car to be competitive it would involve $1800 in mods just to start. That's why I went with a built sra in my cobra
Old 12-02-2012, 07:47 PM   #9
Lorraine's driver
ab_mach1's Avatar
Do you think an aftermarket option would have a less weight increase compared to the Ford IRS too?
Old 12-02-2012, 07:49 PM   #10
There are no aftermarket irs units currently on the market I know of. The problem with the factory unit is ford designed the irs unit around the sra format. It bolts to the lca and quad shock locations.
Old 12-02-2012, 07:53 PM   #11
Lorraine's driver
ab_mach1's Avatar
Wow, when you mentioned that it bolted right up, I assumed there were holes made during manufacturing that ended up on all uni-body stangs to save tooling, etc. They really did slap that in there.
Old 12-02-2012, 07:57 PM   #12
Yupp. There is a bracket that attaches to three holes on each side where quad shock attaches, I believe only two of these are used with the quad shock setup.
I swapped a sra with a irs in under 30 minutes with hand tools, it's really not hard.
Old 12-02-2012, 08:36 PM   #13
From what i have now heard i think i will stick with my Sra and do i build up around it, what are the really good upgrades i should look for parts wise.
Old 12-03-2012, 05:08 PM   #14
What is your car and what is currently done to it?
Also, what are your goals for the car?
Old 12-03-2012, 05:48 PM   #15
Its an 01 GT, the car is currently stock. I want to do a supercharger in a few months would like to do a 6spd swap and autocross the car.
Old 12-03-2012, 05:51 PM   #16
Sonicblue11's Avatar
You better be building that motor bottom up!
Sonicblue11 is offline   Reply With Quote
Old 12-03-2012, 06:43 PM   #17
There is a kit from American muscle that says to be used in "bone stock application" so i should build the bottom end up anyways?
Old 12-03-2012, 08:27 PM   #18
You should always when running boost, the stock crank is good up to 600 hp, I would just to be safe but how much boost do you plan on running?
Old 12-05-2012, 04:24 AM   #19
No more than 8psi, this would be the first time doing a supercharged application is why i asked, ive always been stuck on making it all motor no forced induction of any kind now i dont care power is power haha.
02:01 AM
