new cams - Mustang Evolution
Old 05-11-2008, 02:27 AM   #1
new cams
my 96 gt mustang has 127000 miles on it would anything bad happen to my motor if i install some new comp cams and have everything stock except for my cai
COmustang is offline   Reply With Quote
Old 05-11-2008, 10:51 AM   #2
MonteCitan's Avatar
Re: new cams
Nothing bad should happen assuming you don't contact a piston.. valve springs will probably float, also and should be replaced..
Oh and don't expect too much return if you have even stock exhaust, and non PI heads...
If you're going through the expense and hassle of doing cams.. skip 'em and just go with a set of 99+ GT PI heads... I can about guarantee you'd get a better return off of those than just doing cams on a mostly stock motor..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-12-2008, 07:28 AM   #3
Re: new cams
I would HIGHLY recommend doing a PI swap while you are at it. It REALLY wakes those cars up taking them from the stock 215hp to around 285 (due to higher compression than the 99+ they pick up more hp/tq) and do the cams at the same time.
Old 05-12-2008, 01:03 PM   #4
Herbstang's Avatar
Re: new cams
Great Advise !!!
New Cams? iwannagofast 1996-2004 Mustang GT 18 05-07-2010 02:30 PM
New cams ninty6stang 1996-2004 Mustang GT 3 11-16-2008 10:42 PM
FS: VT Cams hawks05 Mustang Parts for Sale and Wanted 9 12-28-2006 02:48 AM
Cams ridenmystang 1996-2004 Mustang GT 10 12-12-2006 06:12 AM
Cams megax29 Pre-2005 V6 Mustang 11 04-01-2006 12:07 PM
12:00 AM
