Running rich - Mustang Evolution
Old 12-02-2012, 06:40 PM   #1
Matticus's Avatar
Running rich
I believe my o2 sensors have failed and are causing me to run super rich and therefore get terrible mpg. I'm about to replace them, but with it running as rich as it is, will that be hurting anything else? I haven't noticed any other problems yet but it doesn't hurt to check. Thanks.
Matticus is offline   Reply With Quote
Old 12-02-2012, 07:13 PM   #2
Coreyw428's Avatar
Region: Arkansas
Just change the oil after you get the new o2s... It will be okay to drive on till you get them
Coreyw428 is offline   Reply With Quote
Old 12-03-2012, 08:15 PM   #3
cliffyk's Avatar
If you let it go for 2.5 to 5k miles it can cause the catalytic converters to overheat and die...
Old 12-03-2012, 08:41 PM   #4
Matticus's Avatar
O/r x pipe
07:01 PM
