trans - Mustang Evolution
Old 12-04-2012, 10:24 AM   #1
sam minnick's Avatar
trans
Does anyone know if the t56 6speed from the 03 04 cobra will fit in my 99 gt
sam minnick is offline   Reply With Quote
Old 12-04-2012, 10:52 AM   #2
Trbluebullitt's Avatar
Shoot an AM rep a PM and they will let you know i dont know much about trannys sorry
Trbluebullitt is offline   Reply With Quote
Old 12-04-2012, 10:57 AM   #3
Matticus's Avatar
It will but you will have to do a little work first. I believe you'll need a custom drive-shaft which actually isn't as expensive as you'd think. I got quoted around $75. As far as the rest goes someone else may can chime in, but it is definitely possible.
Matticus is offline   Reply With Quote
Old 12-04-2012, 10:57 AM   #4
Mile high JDF's Avatar
Never mind
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-04-2012, 01:38 PM   #5
I have automatic in right now and i know its possible to switch to manual but i didn't know if there was something different about the six speed and or cause the cobra has a 4valve motor in it.. i want the 6speed cause i have 410 gears and could use the extra gear on the highway lol
Old 12-04-2012, 02:10 PM   #6
98vertgt's Avatar
It'll fit. You'll need a new pedal assembly, new clutch, I'm not certain on this but I've been told you'll need a new ECM too.
98vertgt is offline   Reply With Quote
Old 12-04-2012, 02:23 PM   #7
many have went that route, you dont gain much in terms of performance (probalby lose some gearing is not as aggressive for acceleration), you do gain weight and strength to hold more hp/tq though
Old 12-04-2012, 02:32 PM   #8
Faststallion98's Avatar
Or you could buy my 95 cobra trans
---------- Post added at 05:32 PM ---------- Previous post was at 05:32 PM ----------
Cobra r to be more exact
Faststallion98 is offline   Reply With Quote
Old 12-04-2012, 02:52 PM   #9
I went from auto to manual in my old fox body and didnt have to change anything with the ecm... my auto trans shift real strong now but when it goes into overdrive it shifts funny....
---------- Post added at 03:52 PM ---------- Previous post was at 03:51 PM ----------
Your cobra trans is 5 speed isnt it...
Old 12-05-2012, 08:49 AM   #10
It is a 5 speed but its strong as hell and has low miles
Old 12-05-2012, 05:00 PM   #11
I really want a six speed.. whats the difference between your trans and one that would normally be in a gt
Old 12-05-2012, 05:44 PM   #12
93slowstang's Avatar
And it won't work, wrong bolt pattern.
Old 12-05-2012, 05:49 PM   #13
I didnt know that or even think it would be a different pattern
Old 12-05-2012, 05:54 PM   #14
The 95cobra trans is different. The t56 will bolt up fine.
Old 12-05-2012, 06:02 PM   #15
---------- Post added at 07:02 PM ---------- Previous post was at 06:58 PM ----------
Good good
Old 12-05-2012, 10:05 PM   #16
Region: Nevada
Yeah just need the bell housing easy swap
importkiller is offline   Reply With Quote
Old 12-05-2012, 10:10 PM   #17
Yeah, a $500 bellhousing. Might as well get a t45 and save the money.
Old 12-05-2012, 10:19 PM   #18
Region: Nevada
Cheap for a 6speed and stronger trans
Old 12-05-2012, 10:25 PM   #19
I assume youre talking about the t56 then because the t5 is a 5speed and you wouldn't need a bellhousing change for the t56.
Old 12-06-2012, 12:17 AM   #20
Region: Nevada
Lol he wants a t56 that's the question
06:46 PM
