Number 5 misfire please help - Mustang Evolution
Old 12-06-2012, 03:04 AM   #1
cindymansu's Avatar
Exclamation Number 5 misfire please help
OMG i bought this car in May it is sweet looking, only has 68K miles. I have had a number 5 cylinder misfire and 3 shops later no one has figured it out.
We check compression- its fine
Changed plugs, wires and coil packs
Changed the cam sensor, crank sensor, fuel flow sensor
Changed the number 5 injector
Checked all the connections to the injectors
Have done all the normal routine maintanence, Im anal about that
CAR IS STILL NOT FIXED
Again i have the number 5 misfire, the pluged is fouled out and We need help getting this car fixed. I have dumped thousands into this car and no one can figure out, big valley ford couldnt figure it out and sent me on my way telling me its just a fluke
PLEASE I NEED SOME HELP ON WHAT TO DO NEXT. IM SO TIRED OF TRYING TO FIGURE THIS OUT
cindymansu is offline   Reply With Quote
Old 12-06-2012, 03:32 AM   #2
Send a message via Yahoo to Trmahnd725
Check out Ford TSB 96-17-9... Might help
Trmahnd725 is offline   Reply With Quote
Old 12-06-2012, 03:49 AM   #3
cindymansu's Avatar
Thank you I will keep you posted
Old 12-06-2012, 10:12 AM   #4
95v686gt's Avatar
If that doesn't fix it take a noid light to the injector harness and see if its on when the key comes on. If its steady then replace the PCM.
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 12-07-2012, 11:45 PM   #5
1996mustang's Avatar
Possible burnt valve too can cause this imo
Old 12-08-2012, 09:52 AM   #6
2000steeda029's Avatar
Region: West Virgina
Burnt valve would show low compression.
2000steeda029 is offline   Reply With Quote
Old 12-08-2012, 05:09 PM   #7
Gera8712's Avatar
We don't know what the readings are
Gera8712 is offline   Reply With Quote
Old 12-08-2012, 08:12 PM   #8
true if we had readings then we could atleast somewhat diagnose the problem
Old 12-08-2012, 10:29 PM   #9
But was stated compression checked fine
Old 12-08-2012, 11:42 PM   #10
Gera8712's Avatar
But some engines might be close to the 25% range between eachother and still fail(have bad rings,head gaskets,valves,etc)
Old 12-09-2012, 12:01 AM   #11
Depends on what fine is considerrd imo 125 to 140 psi per cylinder would be acceptable for compression on these motors. They couldve said 90 is good which i would not agree with
Old 12-09-2012, 03:51 AM   #12
LAS97GT's Avatar
Couldn't this problem be contributed by a leaking head gasket between # 5 & 6 cylinders? Just asking. When I pulled my stock heads I noticed some sharing between cylinders, but after 15 yrs of use I wasn't surprised.
---Las97GT
Old 12-09-2012, 09:12 AM   #13
True I wouldn't accept 90 paid
---------- Post added at 12:12 PM ---------- Previous post was at 12:11 PM ----------
True I wouldn't accept 90 psi
05:59 PM
