Headlight bulb watts - Mustang Evolution
Old 12-06-2012, 08:40 AM   #1
jdavis96gt's Avatar
Region: West Virgina
I got some new bulbs (gift from eBay) and they say 110 Watts. Is that each or together? I doubt they make 110 watt bulbs but its eBay, so you never know.
I was thinking they're probably 55 watts each, is that to high? They're blue tips and they were less than $15 a set.
I'm worried cause they're high watts and cheap price. So I'm hesitent to put them in.
Thanks
Old 12-06-2012, 09:57 AM   #2
cliffyk's Avatar
The stock headlamps are 65/55 W (hi/lo). Without knowing more about the lamps you received, as in what wattage are they really, it is impossible to judge them.
Are there any markings on the lamps, or further information on the packaging?
Old 12-06-2012, 10:22 AM   #3
jdavis96gt's Avatar
On box-
ICBEAMER --9007- 12v100/80W.
Never noticed before. My buddy gave them to me. He sold his mustang couple weeks ago.
So that's what 100watts high beam, 80 low beam? That's way to many watts huh?
---------- Post added at 12:22 PM ---------- Previous post was at 12:20 PM ----------
Also got fogs. They're 37.5 Watts, to much?
Old 12-06-2012, 10:52 AM   #4
cliffyk's Avatar
The power supply (fuses) and wiring would support them. However I would be concerned about the switches that were designed to accommodate 65/55 W lamps. 100/80 W is 45 to 50% more power, and that means 50% additional heat that might distort the plastic housings.
Your call, as Dirty Harry said "Do you feel lucky today?".
The stock fog lamps are 27.5 W, but many people run the 37.5 W 893 lamps. It really doesn't matter as the stock fog lights are just cosmetic/toy units anyway. Real fog/driving lamps start at 55 W and go up to 100 W, some higher.
As we get some serious fog here, and before I retired I drove to work at 5:00 am, I replaced the stock fog lights with 100 W Hella projectors:
The stock fuses and wiring can handle this as well...
Old 12-06-2012, 11:13 AM   #5
1slosix's Avatar
I know in my old stang i ran 55w hids in my fogs lol...as for a 100w bulb id say your call as well. Imo if you want a brighter light just get hids...
carving corners like a boss
Old 12-06-2012, 11:42 AM   #6
cliffyk's Avatar
Before jumping on the HID wagon read this, and this from Daniel Stern Lighting.
Old 12-06-2012, 12:23 PM   #7
1slosix's Avatar
you know i've read all that before and i'd never give up using HIDs...i've run them in every mustang i've ever owned or ever will own for that matter. it's the first mod i do...and i will always reccomend them
Old 12-06-2012, 12:32 PM   #8
jdavis96gt's Avatar
Thanks guys and no I'm not running the headlights. I am going to run fogs. They're white light bulbs not blue tip, my bad. I thought it was kinda high Watts. Thanks again.
Old 12-06-2012, 01:06 PM   #9
1slosix's Avatar
blue tips on a halogen bulb usually means it's gonna be a white output..a purple tint usually means a blue hint of output
Old 12-06-2012, 01:15 PM   #10
jdavis96gt's Avatar
So I was right, when I thought I was wrong lol. Thanks
12:19 PM
