2000 GT - Mustang Evolution
Old 12-06-2012, 09:07 AM   #1
2000 GT
My car jerks while I'm driving sometimes and at a stop what can be the problem and is it serious?
Paola is offline   Reply With Quote
Old 12-06-2012, 09:54 AM   #2
kickerofdoom's Avatar
Is it a auto
Old 12-06-2012, 10:09 AM   #3
Yes
Old 12-06-2012, 10:17 AM   #4
Change out the fluid should help a bit
Old 12-06-2012, 10:29 AM   #5
Which fluid ?
Old 12-06-2012, 10:36 AM   #6
98vertgt's Avatar
Mine does it too!
98vertgt is offline   Reply With Quote
Old 12-06-2012, 11:14 AM   #7
95v686gt's Avatar
Transmission Fluid.
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 12-07-2012, 12:34 PM   #8
v8pony's Avatar
Don't do it if you have high mileage..many people here specifically on ME have had auto trannys with high mileage and still run strong but decided to change there fluid for the first time at high miles just for maintanence, 100 miles later there trannys were slipping. Many people will agree, and I'm sure many people with disagree, but I've seen it ruin decent transmissions multiple times.
2002 5spd GT
Feb 2013 Mustang of the Month
Old 12-07-2012, 12:35 PM   #9
Venomouz831's Avatar
Maybe a vacuum leak
)02 Gt, Founder of WE2G
Old 12-07-2012, 12:37 PM   #10
v8pony's Avatar
Originally Posted by Venomouz831 View Post
Maybe a vacuum leak
Could be...how's your idle? If its smooth I doubt it's a vacuum leak tho, if its a bit rough id start there.
2002 5spd GT
Old 12-07-2012, 12:40 PM   #11
187,000 everything been good what's idle? It's just started to jerk when I drive and stop sometimes
Old 12-07-2012, 12:44 PM   #12
v8pony's Avatar
187k on stock tranny DO NOT TOUCH THAT FLUID!!!!!!...Idle is the rotational speed the engine runs on when the engine is uncoupled to the drivetrain and the throttle pedal isn't depressed, which simply means when your car is sitting at a red light or sitting anywhere with the engine on, it is idling. When it is idling, check your rpms , does the needle bounce up and down at all? Or is it steady at a specific rpm?
2002 5spd GT
Old 12-07-2012, 01:09 PM   #13
v8pony's Avatar
Also 187k if its the stock auto tranny than its probably just the tranny...my old 99 v6 at 105k miles started to have a hard jerk from 1-2 shifts, was told I needed a new tranny or rebuild, well I just drove it harder, still shifted fine with the jerk at 126k miles when I sold it..I'd say by 187k it's time for a rebuild.
2002 5spd GT
Old 12-07-2012, 01:27 PM   #14
Yes it jumps up and down I'm sorry I'm not good with care rebuild ?
Old 12-07-2012, 01:31 PM   #15
v8pony's Avatar
Check for vacuum leaks, seafoam the car, id start there
2002 5spd GT
Old 12-07-2012, 09:37 PM   #16
1996mustang's Avatar
Could be the idle air contol valve or mass air flow sensor if it bogs up and down the rpms. Start by cleaning the maf sensor and iac with some carb cleaner but use maf cleaner on the maf. That's my suggestion
01:55 AM
