Question about a idle problem with my 2000 gt - Mustang Evolution
Old 12-08-2012, 09:30 PM   #1
DeVellis's Avatar
My can when I'm sitting at light or parked it will idle up to about 1500rpm then almost bog down and almost stall then balance back out I'm at a loss of what it could be anyone have any suggestions ?
DeVellis is offline   Reply With Quote
Old 12-08-2012, 09:35 PM   #2
schmitty426's Avatar
It's your Idle control valve sounds like
schmitty426 is offline   Reply With Quote
Old 12-08-2012, 09:53 PM   #3
Matticus's Avatar
Clean your IAC valve good first, it's an easy thing to do that night fix the problem. If that doesn't work I would try getting some mass air flow cleaner and cleaning the MAF and then the throttle body while you are at it. Those will be the easiest places to start.
Matticus is offline   Reply With Quote
Old 12-08-2012, 10:04 PM   #4
Redstang1's Avatar
If you do clean it make sure your order a new gasket first. I did this when I dd my 2000 gt and ended up having it leak for a week until the local autozone got a new one in
Redstang1 is offline   Reply With Quote
Old 12-08-2012, 11:36 PM   #5
1slosix's Avatar
grab a can of MAF cleaner and clean the MAF, and IAC...then also clean down the TB while you're at it. usually takes care of 99% of idle issues like that
carving corners like a boss
Old 12-09-2012, 12:41 AM   #6
DeVellis's Avatar
I'm kinda a beginner when it comes to this what exactly am I looking for ?
Old 12-09-2012, 03:41 AM   #7
LAS97GT's Avatar
Wouldn't vacuum or stuck throttle cable cause this too. Jus wondering since the throttle climbs then when it drops it goes to the bottom if the rpm band close to stalling.
---Las97GT
Old 12-09-2012, 03:25 PM   #8
jjsg09's Avatar
Here ya go very common problem. Just clean it out.
Old 12-16-2012, 04:38 PM   #9
DeVellis's Avatar
Thank you
Old 12-17-2012, 10:05 AM   #10
replace your IAC... i got a one off e-bay for 30 dollars... the brand is standard, and if its not the problem its better then an 80 dollar motorcraft. if that fixes the problem, wait six months and buy a better brand, then you'll have the 30 dollar one for diagnosing.
don't clean it, it only oxidizes the inside of the valve and strains the electric motor more resulting in an even more tired valve. you won't throw a code till it completely dies.
when you replace that reset your KAM.
Smokum281 is offline   Reply With Quote
Old 12-20-2012, 07:33 PM   #11
DeVellis's Avatar
So I've now noticed that my cars idle shoots up an comes back down only when I have my heat on high does that change anyone's advise as how to fix this?
09:24 AM
