Water in the oil? - Mustang Evolution
Old 12-09-2012, 11:21 AM   #1
Water in the oil?
well i have a 96 mustang gt 4.6 liter,had no water in the oil before but i noticed coolant dripping down on the driver side back of motor.....so i pressure tested the radiator and i noticed water was shootin out of the intake gasket ......but now i have water in the oil after the pressure test??ive been told on these mustangs if intake gaskets blew then no water can get in the oil is this true .....or is this headgasket
lgw8471 is offline   Reply With Quote
Old 12-09-2012, 01:09 PM   #2
Black99Snake's Avatar
Head gaskets are most likely your culprit if its leaking from the back and outside of the engine.
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 12-09-2012, 01:14 PM   #3
any other way to check if its the head gaskets??the water leak i can see is the intake for sure but not sure if that would cause water in the oil thanks for any help
Old 12-09-2012, 01:24 PM   #4
I'm not sure how to check for it but 90% of the time its the head gasket but sometimes oil will puddle in the intake so that's prolly where the water is coming from in the intake
Old 12-10-2012, 09:39 AM   #5
ok thanks ill do some more research as well
Old 12-12-2012, 05:22 PM   #6
LAS97GT's Avatar
I think the rear outlet from the firewall to c-block is not a good design. If it leaks, I expect it will be there. If you have stuff leaking that bad you may need a flush to clear blockage. Water pump will keep pumpin and make things worse.
---Las97GT
Old 12-12-2012, 06:17 PM   #7
DamnLocust's Avatar
To check the HG you could always do a compression test.
DamnLocust is offline   Reply With Quote
Old 12-13-2012, 09:39 AM   #8
ok so i changed the intake gaskets and its doing the same thing water in oil and white vapor out exhaust /water a lot more than normal????
Old 12-13-2012, 09:55 AM   #9
fomoco4life's Avatar
Water in your oil and white smoke out your exhaust definitely sounds like head gasket to me. Compression test should verify that the cylinders where it's leaking should be lower
Old 12-13-2012, 10:00 AM   #10
2300turboford's Avatar
Look in the overflow tank if there is a milky substance in it u have a blown head gasket
Old 12-13-2012, 01:14 PM   #11
i took the spark plug out of number 2 cylinder and its blowing water out and the cylinder is full of water so i am assuming head gaskets ??thanks for all the help
Old 12-13-2012, 01:22 PM   #12
Stang23's Avatar
Ya definitely a blown head gasket
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 12-13-2012, 06:47 PM   #13
LAS97GT's Avatar
Keep the cylinders sealed till you can pull them. Keep oxidation from happening if you can. Not sure but it would be smart thing to do.
---Las97GT
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
This is why you wax your car... illestdomer2005 2011-2014 V6 Mustang 26 06-11-2012 09:45 PM
OEM Factory OIL in the '13 GT - HELP!! Greg3 2011-2014 Mustang GT 5 06-02-2012 05:33 PM
lite water in my oil Mean green 91 1979-1995 Mustang GT 13 01-30-2012 07:15 PM
Oil pressure issues Klinton 1979-1995 Mustang GT 6 09-11-2011 01:52 PM
10:24 PM
