noise coming from shifter? - Mustang Evolution
Old 12-09-2012, 10:30 PM   #1
rodrigo9's Avatar
If if this normal but when I got my gt it had a noise coming from inside the shifter and it came back I mean you can't notice it with the music on or anything bit just wondering if that could be a problem?
rodrigo9 is offline   Reply With Quote
Old 12-09-2012, 11:58 PM   #2
jjsg09's Avatar
Do you have a short throw shifter in it? Or any aftermarket shifter.
Old 12-10-2012, 12:01 AM   #3
rodrigo9's Avatar
No not that I know of it's stock I just got it like last month. I've been wanting to get Hurst shifter to see if that'll take care of it
Old 12-10-2012, 12:19 AM   #4
jjsg09's Avatar
Yea with stock shifter you shouldn't hear much coming from there. Tbe aftermarket one its normal to hear stuff. Might take a video and post it.
Old 12-10-2012, 12:25 AM   #5
rodrigo9's Avatar
Okay I will try and take one this week! I hear the most when I'm in 5th gear though it goes away once I hit 65 to 70 and it can get annoying
Old 12-10-2012, 05:33 AM   #6
v8pony's Avatar
Same there here ahhh can't figure it out, stock shifter, never done it before just randomly started doing it, mainly in 5th gear. It's almost like its growling at me, grrrrrrrrrrr
2002 5spd GT
Feb 2013 Mustang of the Month
Old 12-10-2012, 06:23 AM   #7
jjsg09's Avatar
Does the noise persist throughout the rpms or only at lower rpms? Its normal to hear noise from the shifter if you are at a lower rpms. Shouldn't hear anything the higher the rpms go.
Old 12-10-2012, 08:14 AM   #8
v8pony's Avatar
Yep pretty sure it's more heard before car is up to temp, in 5th gear, at the lower rpms..it's just I got the car 8-9 months ago and just started hearing it about a month ago
2002 5spd GT
Old 12-10-2012, 08:40 AM   #9
jjsg09's Avatar
[QUOTE="NJstanger;1411617"]
---------- Post added at 10:40 AM ---------- Previous post was at 10:38 AM ----------
Try putting a little bit of trans fluid in it and see if it goes away.
Old 12-10-2012, 08:47 AM   #10
v8pony's Avatar
I just changed my tranny fluid it was doing it before I changed it as well...figured maybe it was overfilled a bit cuz I had the notchy 1-2 cold shift on my tremec-3650..so I filled with 3.2 quarts of Mobil 1 atf (what I've been told that's exactly what tremec recommends)
2002 5spd GT
Old 12-10-2012, 10:01 AM   #11
jjsg09's Avatar
How many miles is on the car. Also it might be a worn out clutch/pressure plate.
Old 12-10-2012, 10:05 AM   #12
rodrigo9's Avatar
Mine only does it at lower rpms once I hit like 2000 thousand it goes away and the clutch on mine was replaced about two months ago and mine has 120k
Old 12-10-2012, 10:10 AM   #13
jjsg09's Avatar
Yea mine will make a few grrrr noises if I shift early and is heard more while its cold. Try shifting later as in letting your rpms go higher between shifts.
Old 12-10-2012, 10:12 AM   #14
rodrigo9's Avatar
Okay I will try that when I'm driving normal I usually shift at or before 2500 rpm so maybe I'll try shifting after the 2500
Old 12-10-2012, 10:22 AM   #15
Rosco's Avatar
I would recommend checking to see if you have an aftermarket shifter first. You may be surprised the p.o. put one in and that's the reason to it all. I have a pro 5.0 and it makes a "grrrr" sound at low rpms, but at low speeds and a high gear (Ex: 15 mph in 3rd gear) too.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 12-10-2012, 11:08 AM   #16
1lowGT's Avatar
Got the same one. I rarely notice it, but it's always there people in my car notice it.
Old 12-10-2012, 12:06 PM   #17
rodrigo9's Avatar
Yeah man pretty much same as mine but ill look into it and it gets annoying haha
11:39 PM
