Has the tranny fluid ever been changed? If not drain it and refill with 3.0 L (3.2 qts). This is less than what the owner's manuals says, but exactly what this TSB says.
I had been running RP Synchromax, however have found Mobil 1 ATF to be much smoother. Do not load any additives, Tremec is quite explicit that they should not be used, this is from the TR-3650 service manual:
Yeah if the lube change doesn't work also check the clutch slave cylinder that can be going out as well. I hope its not syncros that could be expensive.
Nice picture. I think I have a squeak around the clutch release lever. Originally thought it was the quadrant but the noise was comin from underneath. Happens usually when I slowly release the clutch pedal. Havent had a chance to pull the dust cover off and check.
Sent from my GT-P3113 using Mustang Evolution mobile app
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
