Need an idea - Mustang Evolution
Old 12-10-2012, 06:24 PM   #1
2000_gt's Avatar
Need an idea
I wanting around 500rwhp. I know it will involve engine work but I dont know what that's why I'm asking. My plan is twin screw or on3 I have around 8k to play with. Someone give me some ideas please
2000_gt is offline   Reply With Quote
Old 12-10-2012, 07:44 PM   #2
Speed_Mister's Avatar
Region: Arkansas
I'd stay N/A route. You can get cold air intake, 78mm throttle body and plenum, pi manifold swap, heads, big cam, long tube headers with x-pipe off road(no cats), exhaust, under drive pulleys, dyno jet tune it, get bigger injectors, and a better fuel pump for more fuel, delete ac pulley to get more extra horsepower that'll put you around 470ish rwhp
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-10-2012, 07:49 PM   #3
1slosix's Avatar
I vote FI....but i recommend looking into a centri. ;
carving corners like a boss
Old 12-10-2012, 07:56 PM   #4
2300turboford's Avatar
On3 turbo would make the most power
Old 12-10-2012, 07:57 PM   #5
Eturner's Avatar
If you can do all the work yourself, then you can go with the On3 Turbo and do both heads and cams for all under $8,000!.. And that will put you at about 500hp!..
Old 12-10-2012, 08:04 PM   #6
2000_gt's Avatar
What do I need done to heads like I don't know what to have done.
Old 12-10-2012, 08:08 PM   #7
Trick flow heads with turbo cams
Old 12-10-2012, 08:13 PM   #8
2000_gt's Avatar
Where's a good place to buy these
Old 12-10-2012, 08:19 PM   #9
Eturner's Avatar
+11. With Trick Flow!.. And at least stage 2 cams!..
---------- Post added at 10:19 PM ---------- Previous post was at 10:18 PM ----------
Check out American Muscle and CJ Pony Parts!..
Old 12-10-2012, 08:20 PM   #10
2000_gt's Avatar
I didn't see trick flow heads on there unless I over looked it and does anything need to be done to the bottom end of motor
Old 12-10-2012, 08:24 PM   #11
Eturner's Avatar
There site at times needs some navigating through!.. Lol. You can also get ahold of the AM reps on this forum too!.. They will help you out!.. As for the bottom end, you'll need to beef that up eventually!.. But that also depends on how much Boost you want to push right now too!..
Old 12-10-2012, 08:26 PM   #12
2000_gt's Avatar
I found them on cjpony but I do like AM much better
Old 12-10-2012, 08:37 PM   #13
2000_gt's Avatar
Old 12-10-2012, 08:39 PM   #14
Mile high JDF's Avatar
Um I don't know what planet you're on but nobody is gonna get 470rwhp out of full bolt-ons....
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-10-2012, 08:44 PM   #15
Maybe 350 at the most
Old 12-11-2012, 09:38 AM   #16
WheelStander's Avatar
Mmr and summit are cheaper usually.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 12-11-2012, 11:03 AM   #17
Closer to 310 I would say
03:59 AM
