plenum spacer - Mustang Evolution
Old 12-11-2012, 08:12 PM   #1
scottiep101's Avatar
plenum spacer
Is this a gimmick? Or is it actually worth the $20 I spent on it?
scottiep101 is offline   Reply With Quote
Old 12-11-2012, 08:15 PM   #2
Eturner's Avatar
They are good for maybe 2-3hp on a NA motor!..
Old 12-11-2012, 08:21 PM   #3
I'm going to upgrade tb/plenum too but was wondering about the spacer. I'm getting the trick for plenum tb combo, 75mm. With those 3 thing will I feel a difference?
---------- Post added at 10:21 PM ---------- Previous post was at 10:21 PM ----------
Trick flow*
Old 12-11-2012, 08:43 PM   #4
Eturner's Avatar
Trick flow*
You will feel bit of a difference in HP, but mostly in the throttle response!.. Throw in a tuner into it and you'll notice a bigger difference!..
Old 12-11-2012, 09:23 PM   #5
Venomouz831's Avatar
Maybe like half a horsepower
)02 Gt, Founder of WE2G
Old 12-12-2012, 02:49 AM   #6
I'm tuned, got a custom tune from the local mustang shop and ill have it re tuned after upgrade. I've also got o/r h pipe with flowmasters
Old 12-12-2012, 04:56 AM   #7
Eturner's Avatar
Then you should notice a good jump in HP!..
Old 12-12-2012, 06:16 AM   #8
Could you estimate about how much hp ill have?
Old 12-12-2012, 09:49 AM   #9
Speed_Mister's Avatar
Region: Arkansas
I've heard that 5.0 magazine tested the spacer and after install of the spacer it was a tenth a second slower. Idk if its true or not but its what I've heard.
---------- Post added at 10:49 AM ---------- Previous post was at 10:48 AM ----------
I had a sr racing spacer I think it gave me maybe 5 horsepower or something really small. I took it off though cause now I have a 75mm tb/p
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-12-2012, 10:00 AM   #10
You wouldn't want the spacer to go along with tb/plenum?
Old 12-12-2012, 10:10 AM   #11
Region: Arkansas
Well everybody says 75 is to big for n/a and it kinda made me question myself with the spacer on to.
Full Bolt Ons
370rwhp 470rwtq
Old 12-12-2012, 10:16 AM   #12
What does n/a mean?
Old 12-12-2012, 10:18 AM   #13
sally2002's Avatar
What does n/a mean?
Naturally aspirated
sally2002 is offline   Reply With Quote
Old 12-12-2012, 10:20 AM   #14
Region: Arkansas
I go to a 1000 foot track without the 75mm tb/p but with the spacer I ran a 10.72 with the 75mm tb/p but without the spacer I ran 10.65 so idk I need to put it back on and test it out so I can find out the real truth behind it to see if it does add horsepower most people say it doesn't do anything I wanna find out.
Full Bolt Ons
370rwhp 470rwtq
Old 12-12-2012, 10:23 AM   #15
Got it, so how does 75mm run on an n/a? Would the spacer be ok on 70mm?
Old 12-12-2012, 10:30 AM   #16
Region: Arkansas
Oh my 75 is amazing I love it the throttle it is so sensitive now I love it!
---------- Post added at 11:30 AM ---------- Previous post was at 11:28 AM ----------
Ill put on the spacer and tell you how it feels. 75mm tb/p is way better than the spacer but ill try the spacer with the 75 and tell you how it goes. I'm sure it'll be okay.
Full Bolt Ons
370rwhp 470rwtq
Old 12-12-2012, 10:38 AM   #17
Oh man that would be awesome!
Old 12-12-2012, 10:40 AM   #18
Region: Arkansas
Ill do it tonight and let you know either late tonight or tomorrow how it is.
Full Bolt Ons
370rwhp 470rwtq
Old 12-12-2012, 10:54 AM   #19
Thanks man, appreciate it
Old 12-12-2012, 02:07 PM   #20
Eturner's Avatar
I've got a buddy that has a 2002 GT that is Supercharged!.. He added on a custom made 1 inch spacer and gained just over 10hp!.. I think he said he was running about 12lbs of boost too!...
Old 12-13-2012, 05:59 PM   #21
Region: Arkansas
So I put it on managed to break one of my bolts that bolt the plenum down to the manifolds! Yay! Ill have to go back and drill it out. But with the spacer and 75mm tb/p I could tell a difference. Not very big but enough difference I'm keeping it on. And I'll official test her out in January when the track opens see if I can get that 10.65 down with the spacer I think It will.
Full Bolt Ons
370rwhp 470rwtq
Old 12-13-2012, 06:14 PM   #22
You say 10.65? What do you have done to your mustang?
Old 12-13-2012, 06:20 PM   #23
Region: Arkansas
Hahah alot.. Spent way to much money for being in high school. Cold air induction, 75mm tb/p, under drive pulley's, sct bama 93 race tune, o/r x-pipe, flow master mufflers, king cobra clutch, 4.10 gears with a posi 31 spline differential and axles with Hoosier slick on back and 245's in front.
---------- Post added at 07:20 PM ---------- Previous post was at 07:20 PM ----------
And Now with a sr spacer..
Full Bolt Ons
370rwhp 470rwtq
Old 12-13-2012, 06:33 PM   #24
LAS97GT's Avatar
10inch pounds!
---------- Post added at 08:33 PM ---------- Previous post was at 08:32 PM ----------
What else? That can't be all, what about the chassis?
---Las97GT
Old 12-13-2012, 06:34 PM   #25
Region: Arkansas
Originally Posted by LAS97GT View Post
10inch pounds!
Do what?
Full Bolt Ons
370rwhp 470rwtq
Old 12-13-2012, 06:39 PM   #26
10.65 in the 1/8?
Ryan7racin is offline   Reply With Quote
Old 12-13-2012, 06:40 PM   #27
Region: Arkansas
Originally Posted by Ryan7racin View Post
10.65 in the 1/8?
Hahah no 10.65 in 1000 foot my 1/8 are like 8.25.
Full Bolt Ons
370rwhp 470rwtq
Old 12-13-2012, 07:01 PM   #28
Region: Arkansas
[QUOTE="LAS97GT;1416728"]
10inch pounds!
What else? That can't be all, what about the chassis?[/
It's a 5 speed manual. I did move my battery to the back, removed ac to free up pulley's, I took out spare and jack. No suspension mods or anything.
---------- Post added at 08:01 PM ---------- Previous post was at 07:57 PM ----------
I did remove front sway bar. Hmm yeah that's it.
Full Bolt Ons
370rwhp 470rwtq
Old 12-14-2012, 05:49 PM   #29
LAS97GT's Avatar
The TB bolts into the manifold inserts are 10 inch pounds so you don't snap anymore bolts. Buy a torque wrench, or go buy a Chevy! Hah!
---Las97GT
Old 12-14-2012, 07:26 PM   #30
Eturner's Avatar
I think he wants to work on his car less!.. So Don't Buy a Chevy!!.... Lol
Old 12-14-2012, 09:45 PM   #31
Region: Arkansas
I actually work on my car a lot cause its fun to me.. Not because It breaks but cause I always find new ways to make it faster and really that's all I car about and some descents looks.
Full Bolt Ons
370rwhp 470rwtq
Old 12-14-2012, 10:23 PM   #32
1996v6stang's Avatar
Agreed but ntm why pay someone to do something that you can do?
1996v6stang is offline   Reply With Quote
05:59 AM
