foglamp interrupter relay - Mustang Evolution
Old 12-12-2012, 12:55 AM   #1
Speed_Mister's Avatar
Region: Arkansas
Didn't buy the kit for 13$ instead I pulled this relay out of my fuse box and pulled a small pin of the 5 pins on the relay and plugged it back in, now I can use high beams and my fog lights on at the same time. Anybody else done this mod before?
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-12-2012, 09:27 AM   #2
cliffyk's Avatar
Yes, it is rather common...
Old 12-12-2012, 09:34 AM   #3
Region: Arkansas
Everybody at my school that I talk to about it didn't know anything about it. Lol whoever came up with this is a genius I always wanted my brights and fog lights on..
Full Bolt Ons
370rwhp 470rwtq
Old 12-12-2012, 09:56 AM   #4
cliffyk's Avatar
Here's a post from 2006, from another forum, outlining the process.
Here is another modification I described earlier this year that lets them be turned on without the parking or headlamps on:
The new jumper wire is wired in between the fog lamp switch and the rear window defrost switch in the center console...
Old 12-12-2012, 10:08 AM   #5
Region: Arkansas
Here's a post from 2009, from another forum, outlining the process.
So all I have to do is splice in a wire connecting the fog lamp switch to the rear window defrost switch in the center console.?
Full Bolt Ons
370rwhp 470rwtq
Old 12-12-2012, 10:14 AM   #6
cliffyk's Avatar
And cut the brown wire at the fog lamp switch, from the main light switch--otherwise the parking lights will be one all the time...
Old 12-12-2012, 10:25 AM   #7
Region: Arkansas
Thanks I'm gonna have to try that sometime!
Full Bolt Ons
370rwhp 470rwtq
Old 12-12-2012, 11:44 AM   #8
98GTCONV's Avatar
Is this the same for 96-98s?
98GTCONV is offline   Reply With Quote
Old 12-12-2012, 11:56 AM   #9
Region: Arkansas
Yes. Well probably most likely.
Full Bolt Ons
370rwhp 470rwtq
Old 12-12-2012, 12:15 PM   #10
cliffyk's Avatar
I have no factory wiring diagrams for anything older than '99, however as this is all purely electro-mechanical (no electronics) it is likely the same--probably even the same wire colours...
Old 12-12-2012, 12:26 PM   #11
Region: Arkansas
Basicall 96-98 and 99-04 are basically the same except few differences like the body obviously. you can do the fog light relay for sure if you have a fog light button and defrost button then it is possible if i were you id take it apart and look at it see if you have a brown wire and a light blue/pink wire if not id look at you cars manual book it should have a factory wiring diagrams.
Old 05-08-2013, 10:36 PM   #12
Region: Arkansas
This thread is old but on new cars most high beam come on with low beams is there anyway I can make my 2003 mustang do this I hate how only my high beams come on its so much better when my high beans and low beans are on when I pull the leaver back.
Full Bolt Ons
370rwhp 470rwtq
01:16 AM
