Transmission - Mustang Evolution
Old 12-12-2012, 07:14 PM   #1
Wheelieman618's Avatar
Transmission
I have a 97 gt auto i wanna swap it to 5spd i have a wreckd 6 cyl is it all the same or i gotta find a v8 doner
Wheelieman618 is offline   Reply With Quote
Old 12-12-2012, 08:21 PM   #2
DamnLocust's Avatar
The V6 uses a different transmission (T-5 in the V6, T-45 in the GTs) and the bellhousing does not match up.
Might as well look into getting yourself a TR-3650, the transmission from late '01-04 GTs. They're more robust than the T-45s that originally came in early 4.6 cars. The only thing is you'll need to get ahold of a mechanical speed sensor.
DamnLocust is offline   Reply With Quote
Old 12-12-2012, 08:26 PM   #3
Do you know if its cable clutch nd i dnt need any wire harnesses 2 do the swap i have a mustang junkyard 10 min from my house he has it all
Old 12-12-2012, 09:24 PM   #4
DamnLocust's Avatar
It literally will not bolt up to your motor unless you waste a couple hundred dollars on an aftermarket bellhousing. It just isn't worth the effort and extra money to make it work. What you'd spend on the bellhousing is probably more than the extra cash needed to get the proper transmission.
Take the pedals, the shifter surround, even the shifter if you're going with a T-45. That's about all you can use.
Old 12-12-2012, 09:47 PM   #5
Na im gunna get a set of gt pedals nd tranny do u kno wat else is needed
Old 12-12-2012, 09:56 PM   #6
DamnLocust's Avatar
There's no difference between V6 and V8 pedals. Might as well pick them up now while you have the chance and a source. Same goes for the interior shifter trim.
You need a flywheel, clutch, transmission, shifter, cable, and driveshaft. Might need a different crossmember as well, but I'm not 100% sure of that. Trans mount is specific for 96-98 cars with the T-45 as well, so you'll need one of those too.
I honestly don't know what would be needed when it comes to the wiring/ECU. You may need some kind of adapter for the speedometer, I don't know if the AOD uses the same type of sender that the T-45 does.
Old 12-13-2012, 11:45 AM   #7
Mile high JDF's Avatar
There are plenty of auto to manual threads on here, just do a quick search and you should find all that you need
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
02:24 PM
