Stupid rim question - Mustang Evolution
Old 12-14-2012, 06:02 AM   #1
Polar Bear's Avatar
Region: Asia
Stupid rim question
I live in Japan. That is first problem. I won a 97 Mustang GT and have been scouring this island for rims. Found a pair today that I believe will fit (Japanese hubs are smaller and their rims won't fit) with Firestone tires. I put one rum on my car and it went on perfectly. Here's the question. When I went to put the lug nuts on the lug holes in the room were just big enough for the lug to fit but no room for a wrench. Is there anyway around this?
---------- Post added at 10:02 PM ---------- Previous post was at 10:01 PM ----------
Own a 97 Mustang GT not won. Stupid auto spell.
Steve
Polar Bear is offline   Reply With Quote
Old 12-14-2012, 06:34 AM   #2
taylor98gt's Avatar
Smaller nuts.
taylor98gt is offline   Reply With Quote
Old 12-14-2012, 06:55 AM   #3
Polar Bear's Avatar
Region: Asia
Ok factory size are what? 3/4"? 13/16? Are there smaller?
Steve
Old 12-14-2012, 09:49 AM   #4
Venomouz831's Avatar
I had the same problem when I tried to fit the 21mm lugs on an aftermarket rim basically the crossbar wouldn't fit in the hole so I had to buy 19mm lugs on eBay
)02 Gt, Founder of WE2G
Old 12-14-2012, 10:00 AM   #5
IanM's Avatar
I had a similar issue with a set of wheels and ended up using a set of "tuner" style lugs from a company called Gorilla Lug Nuts. They have a key tool that fits down into the tight lug hole which has splines that are keyed to the new lug nuts. You can't use an impact on them, as the wheel shop found out the hard way, but this should work for you. I found a similar set on Summit Racing's site, http://www.summitracing.com/parts/go...c/media/images
Hope this helps you get your wheels on, might take a bit to get them where you are, but it will solve the clearance issues.
2011 Grabber Blue GT California Special, 3.73 Gears, 6-Speed Manual, Steeda CAI, Steeda 93 tune, aluminum driveshaft (The Driveshaft Shop Co.), MGW shifter, Roush axle-back exhaust, Roush Side Rocker Panel Splitters, Ford Racing BOSS 302 front splitter, sound-tube delete, painted plug covers, JLT oil separator. Shelby transmission scoop & powder-coated trunk brace & many more items...
IanM is offline   Reply With Quote
01:05 PM
