Starting in 2nd gear always - Mustang Evolution
Old 12-14-2012, 06:36 PM   #1
v8pony's Avatar
Whatsup guys...02 GT tremec-3650 here..so I f'ing hate 1st gear, It's so super short, and even if I take off relatively quick in first when I hit the clutch to shift at say 3k than I seem to lose soooooooo much momentum by the time I shift to 2nd and release the clutch..question is, is it safe to drive launching in 2nd lets say 90% of the time? Any harm to the tranny or anything, I could see how it may add to wear on the clutch due to more slipping but I almost feel that by skipping having to slip the clutch to take off in first than again a slight slip to get from 1st to 2nd is about equal the wear on the clutch I would imagine...what's your input on this guys? I know I've searched this a few times but everywhere I read about it on our stangs it seems to be a gray area and can't really find a definitive answer if its gonna screw anything major up or not..thanks guys
2002 5spd GT
Feb 2013 Mustang of the Month
Old 12-14-2012, 06:39 PM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
no real harm except like you said clutch wear. it'll be harder on the clutch taking off in second than in first for sure though, also it'll put a little more stress on the engine too, not too much but more.
sounds to me like you need a longer gear. what gears do you have now?
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 12-14-2012, 06:53 PM   #3
v8pony's Avatar
No idea I believe stock..50 mph puts me right about 2k rpm in 4th gear if I remember correctly..
2002 5spd GT
Old 12-14-2012, 06:55 PM   #4
The Blue Dragon
that doesn't really tell us anything, but I would probably go with a 3.73 gear, from what you're saying sound like you may have 4.10's or shorter
Old 12-14-2012, 07:16 PM   #5
2300turboford's Avatar
How many rpms are u running at 70?
---------- Post added at 09:16 PM ---------- Previous post was at 09:16 PM ----------
In 5th gear
Old 12-14-2012, 07:36 PM   #6
v8pony's Avatar
In 5th gear
Im pretty sure right about 2k I believe
2002 5spd GT
Old 12-14-2012, 08:34 PM   #7
jjsg09's Avatar
I've heard doing that tears up your clutch fast. I wouldn't recommend it.
Old 12-14-2012, 08:44 PM   #8
FortyBrandon's Avatar
Lol sometimes I come to a complete stop in 2nd and take off accedently lol
FortyBrandon is offline   Reply With Quote
Old 12-15-2012, 08:02 AM   #9
WheelStander's Avatar
Probably causing engine detonation too.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 12-15-2012, 08:11 AM   #10
v8pony's Avatar
Just seems no matter how quick I shift that 1-2 shift I lose so much momentum before gunning it in 2nd
2002 5spd GT
Old 12-15-2012, 09:07 AM   #11
You might want to swap to an auto...
Apex Predator is offline   Reply With Quote
Old 12-15-2012, 09:51 AM   #12
You got the stock 3.27 I'm at the same thing at 50mph
Ryan7racin is offline   Reply With Quote
Old 12-15-2012, 11:20 AM   #13
The Blue Dragon
Do you both have the same size tires? That will also determine speed at certain rpms. What's to say his speedo is even calibrated
Old 12-16-2012, 09:41 AM   #14
cliffyk's Avatar
Sounds like stock 3.27s, here's a link to my "How Fast can I Go in Each Gear?" calculator that will help in sorting it. Toward the upper right of the calculator page is an Axle Ratio Calculator, that is more accurate then I thought it would be if you feed it accurate input data.
The most precise way however is to jack up the back-end and count haw many revs the driveshaft turns for one turn of the wheel--while you are under there take a look at the tag on the tranny, it will have 3L27 stamped on it if it's the stock gears (and of course if they have not been swapped out).
I have the same issue in 1st gear with my 3.73s, exacerbated by the flat land here in NE Florida and the damned lime-rock McAdam that wears smooth as glass. 1st in worthless and I launch in 2nd most all the time. When the 3650 lets go I will be looking at the TKO-600 with the 2.87:1 1st gear (the stock 1st gear is 3.38:1) or a custom built 3650 with that same 1st gear ratio...
Old 12-17-2012, 06:03 PM   #15
1lowGT's Avatar
I'm barely under 2k at 70moh I 5th 3.27s
Old 12-17-2012, 06:10 PM   #16
I'm at the same, also stock 3.27.
I love the stock gears for long road trips on the interstate, this weekend I went on a little trip to New Orleans and got 26mpg all the way there and back.
Old 12-17-2012, 06:15 PM   #17
1lowGT's Avatar
Yeah but I'm wanting 3.73 lol. Beat I've got was like 22 this colder weather I'm at 115 miles and half tank lol
Old 12-17-2012, 06:19 PM   #18
I want 3.73 too I do mostly city driving, but the Interstate gas mileage is so amazing. I'm shocked I get that much.
Old 12-17-2012, 06:21 PM   #19
1lowGT's Avatar
I don't think it will
Hurt that much
Old 12-17-2012, 06:24 PM   #20
Hurt that much
I don't either and like I said I do mostly city driving so it will more than likely help me.
But I'm not really worried about MPG but its nice to see them numbers from a mustang GT
Old 12-17-2012, 06:31 PM   #21
1lowGT's Avatar
---------- Post added at 07:31 PM ---------- Previous post was at 07:31 PM ----------
Whoops lol didn't mean to do that. But yeah that's true
Old 12-17-2012, 06:46 PM   #22
Butch's Avatar
Region: New Mexico
I took off in second yesterday and yeah that wont happen again, brutal
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 12-17-2012, 06:47 PM   #23
1lowGT's Avatar
I've done it once on accident. Lol
Old 12-17-2012, 07:03 PM   #24
9tee7pony's Avatar
I did 3rd once just to see if I could do it. It worked but definitely won't be doing it anymore.
9tee7pony is offline   Reply With Quote
Old 12-17-2012, 07:31 PM   #25
I accidentally did that in our corvette at a light once, but it was my 1st time driving stick so you can probably guess what happened.
Old 12-17-2012, 07:39 PM   #26
1lowGT's Avatar
Clunk. Lol
Old 12-17-2012, 08:04 PM   #27
9tee7pony's Avatar
The only time that I stall anymore is when I forget it is still in gear. Happens more than you think it would.
Old 12-17-2012, 08:40 PM   #28
1996mustang's Avatar
pretty spiffy calculator cliffyk, appearantly in 5th im at 75.6 mph at 2k rpms, deff makes sense lol. although i wonder in 1st i can get to 41 mph imma try that out later to see how accurate that calculater is, pretty nice to know though that i can top out at 207 mph if i can ever have enough room to get there lol.
Old 12-17-2012, 09:14 PM   #29
cliffyk's Avatar
Here is my "How Much HP Does It Take to Go How Fast?" calculator.
You need to correlate your engines' power output at the corresponding RPMs to make it all work, which is a bit complex--however keep in mind that when talking top speed 250 HP at 5500 rpm means nothing unless your engine is turning 5500 rpm at top speed...
Old 12-17-2012, 09:51 PM   #30
seems i need to gain roughly 175 hp more lol. nice to know i like the site u have, i did my o2 deletes how it said to use the capacitor and resistance, works like a charm
11:34 AM
