high idle - Mustang Evolution
Old 05-16-2008, 05:48 PM   #1
Region: Nevada
high idle
This doesnt happen every single time but often when I turn on the AC while driving, my car idles at about 2k RPM. And for some reason it seems to happen even more often when im low on gas. If I turn off the car for a couple minutes and leave the AC off when I start the car again, it seems to go back to normal. Anyone have an idea how to fix this? Thanks in advance
chris098 is offline   Reply With Quote
Old 05-16-2008, 06:33 PM   #2
Black Vert's Avatar
Re: high idle
When you turn the a/c on the compressor comes on which draws power from the engine. Therefor the engine has to work harder. Thats why the revs go up a little.The computer will regulate the compressor going on & off while the a/c is on. So your revs will go up & down just a tad as the compressor go's on & off. As far as being low on gas I dont think it has anything to do with it.
04 GT Convertible
Steeda CAI, Accufab 75mm TB/Plenum, Magnaflow Catted X pipe, Borla Catback, Steeda Tri Ax Shifter, Classic Light Bar, Federal SS595 245/45/17 Bullitt Rims
Black Vert is offline   Reply With Quote
87 Mustang has very high idle and running VERY rich. Any ideas? clannan1 1979-1995 Mustang GT 5 08-21-2010 11:25 AM
Idle sticking Rascal Pre-2005 V6 Mustang 2 08-11-2010 02:18 PM
Doesn't idle down. Joe_SHO Pre-2005 V6 Mustang 7 02-12-2009 07:44 AM
High RPM idle electricstang Pre-2005 V6 Mustang 4 09-25-2005 12:55 AM
At idle ASSEMbler Pre-2005 V6 Mustang 14 08-07-2003 01:54 AM
07:13 AM
