Dash buttons conversion - Mustang Evolution
Old 12-17-2012, 03:20 PM   #1
ToHellAndBack's Avatar
I was wondering if it would be possible to replace the 3 dash buttons by the shifter ( rear defroster, tc, and fogs) with something like in this picture.
I would fab up my own aluminum plate to hold three led toggle switches. I really like the race car style of the switches and my main question is if its possible to get it to work.
"I'm not tailgating... I'm drafting"
ToHellAndBack is offline   Reply With Quote
Old 12-17-2012, 04:15 PM   #2
schmitty426's Avatar
A little wiring mod. And it should work I don't see why it wouldn't
schmitty426 is offline   Reply With Quote
Old 12-17-2012, 04:32 PM   #3
It's not me, it's you.
primer2tone's Avatar
Where would you mount that?
Old 12-17-2012, 06:19 PM   #4
Blogger
99ford's Avatar
+1 You'd have to reconfigure a few things.
Old 12-17-2012, 06:29 PM   #5
Barrett775's Avatar
Region: Wyoming
I just wanna say that is an awesome idea. Kept us posted on this if you decide to go that way.
Barrett775 is offline   Reply With Quote
Old 12-17-2012, 08:34 PM   #6
cliffyk's Avatar
What year is your car?
It matters because the specific functional nature of the switches changed over the years--some moved from being positive action to momentary, etc...
Old 12-17-2012, 08:42 PM   #7
1996mustang's Avatar
indeed please keep us updated as to how u go about it, i would love to know as well if i choose to do the same then we would have a write up on how
Old 12-18-2012, 04:35 AM   #8
It's an 02 gt
Old 12-18-2012, 09:14 AM   #9
cliffyk's Avatar
It's an 02 gt
On the 2001 through 2004 models the fog lamp switch is a single pole single throw (SPST) ON-OFF switch. The rear window defroster and traction control switches are both SPST momentary contact (ON)-OFF units (the ON in parentheses indicates that is the momentary position).
Replacing any of these would just require having an appropriately configured switch and wiring it across the wires leading to each of the stock switches as indicated below.
Here are the switch diagrams;
fog lamp - ON-OFF to the brown and white/black wires:
rear window defrost - (ON)-OFF to the pink/light blue and black/yellow wires:
traction control - (ON)-OFF to the pink/black and gray:
In all three switches the switch illumination and indicator lamps are LEDs. Shown below is the t/c switch, the others are similar:
But there's a gotcha!
The LEDs have built-in dropping resistors so that they can be operated from a 12V source without an external current limiting resistor. Radio Shack does not sell such devices, however they are available--here's an outfit that does supply them.
Old 12-18-2012, 11:33 AM   #10
So the wiring for the switches would go across what you hi lighted on the diagram? And do I need a special switch?
Old 12-18-2012, 11:44 AM   #11
Would a toggle switch like in the picture work for tc and defroster even though they are momentary contact?
Old 12-18-2012, 12:06 PM   #12
cliffyk's Avatar
If it were momentary contact toggle switch.
A "regular" switch could be used, however you would have to switch it on and then immediately off to toggle the t/c or defroster on/off. The instrument cluster senses the trailing edge of the pulse generated when the switch is switched on and then off--I.e. it senses when you release the switch, not when you press it.
I believe the vendors of switches as you have shown do make matching momentary contact devices...
Old 12-18-2012, 12:28 PM   #13
So a switch like this would work?
http://www.colehersee.com/home/item/cat/46/55020/
Then I would just buy the military style cover
Old 12-18-2012, 12:31 PM   #14
Venomouz831's Avatar
That will look sick!!
)02 Gt, Founder of WE2G
Old 12-18-2012, 12:34 PM   #15
I'm gonna head down to radio shack and see if I can pick up 3 spst toggle switches with the covers. For defroster and tc I will just switch them on and off.
Old 12-18-2012, 12:39 PM   #16
TXstang125's Avatar
keep us posted man , I've been wanting to do the same for a while but never got that into it :/
TXstang125 is offline   Reply With Quote
Old 12-18-2012, 12:41 PM   #17
cliffyk's Avatar
Toggle Switches | Heavy Duty Toggle Switches 25A | SPST Momentary 25A Toggle Switches55020 | Cole Hersee - Littelfuse
Yup, that's the one...
Old 12-18-2012, 12:46 PM   #18
Lorraine's driver
ab_mach1's Avatar
They make momentary switches that basically look just like toggle switches. I would think Radio Shack would have them. Based on previous posts on this thread, it sounds like you need one SPST toggle switch and two momentary toggle switches.
Instagram: @ab_mach1
Old 12-18-2012, 12:48 PM   #19
Lorraine's driver
ab_mach1's Avatar
I see now that you figured ^that out.
Old 12-18-2012, 05:42 PM   #20
Hey guys I just picked up the toggle switch for the fogs. Radioshack didn't have the momentary switches. Does anyone know how to wire this?? Sorry for all the questions!
ID:	81621   Click image for larger version
Old 12-18-2012, 11:42 PM   #21
runvsofthisbull's Avatar
One is the is ground, one is power, and one (middle) is the relay. You would need to run independent wires to this switch then solder them on. I'd not even mess with this. Not to bash your idea on this but I think someone needs to give you some constructive criticism. Just my thoughts, but really what added benefit will be gained?
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 12-19-2012, 06:54 AM   #22
cliffyk's Avatar
These are not illuminated or indicator switches so there is no need for a ground connection to the switch. He is simply replacing the stock switches with the SPDT (Single Pole Double Throw) units from Radio Shack.
I edited the photos in my posting above to show how the switches would be connected, but here they are again anyway.
As to why the OP is undertaking this project I have no idea, and personally think it will look like crap--however far be it from me to judge other people's tastes, or dissuade anyone from pursuing a vision...
Old 12-19-2012, 11:00 AM   #23
Well you just did judge it with that statement. Now if those switches were to function another process I'd be all for it. Most people post to get opinions on issues and ideas on here and I simply gave mine.
Old 12-19-2012, 11:10 AM   #24
Lorraine's driver
ab_mach1's Avatar
^What's the problem then?
Old 12-19-2012, 11:23 AM   #25
Umm there is no issue. It's not my car so he/she can do as they please. IMO it's just a not a mod that I would partake in. I simply expressed that not to persuade the author to change his mind, but rather to explore his options. That's all. I have no problem with anyone wanting to mod there ride, after all that's what all of us are doing on here.
05:03 AM
