Service engine soon ugh - Mustang Evolution
Old 12-19-2012, 06:43 PM   #1
v8pony's Avatar
So warmed my car up today for about 5 minutes before I left today..got in and boom service engine light...I know I have a weird sound coming from my exhaust but its been like that with no light and my mechanic told me my baffles in my mufflers are bad..so decided to upgrade my whole catback to SLP LM1 which are ordered from AM, installing hopefully this Friday or Saturday, ill have my mechanic check it out but could this possibly be a problem that is going to be fixed with a new catback? Car drives , runs, idles, all good and the same, nothing unusual I notice at all..thanks guys
2002 5spd GT
Feb 2013 Mustang of the Month
Old 12-19-2012, 07:00 PM   #2
1lowGT's Avatar
I doubt a new catback will fix that. Take it to him and have him check it out
Old 12-19-2012, 07:21 PM   #3
JetLife 01GT's Avatar
What code is it throwing? Go to autozone and have them read the CEL for free if you don't have a tuner
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 12-19-2012, 07:21 PM   #4
v8pony's Avatar
Is it bad to be driving?
2002 5spd GT
Old 12-19-2012, 07:26 PM   #5
Um it depends. If you can't noticeably feel or see anything wrong you'll probably be okay. I'd take the risk to run over to autozone so you can diagnose the problem. Watch all ur gauges and make sure engine isn't smoking or making funky noises besides the exhaust noise you said you've been having
---------- Post added at 06:26 PM ---------- Previous post was at 06:25 PM ----------
Or borrow a friends/parents car if you are really worried about it. You can rent those code readers from them
2001 GT
Old 12-19-2012, 07:49 PM   #6
1lowGT's Avatar
+1
Old 12-20-2012, 05:19 PM   #7
v8pony's Avatar
Pep boys pulling codes for me now..ill post the code soon guys, appreciate the help
2002 5spd GT
Old 12-20-2012, 05:42 PM   #8
1996mustang's Avatar
id like to know what they recommend as well when they pull the codes, i work at a pep boys in miami and usually what we do is we tell a client what can cause the problems but of course to actually narrow it down and be 100% u get charged a diagnostic.
Old 12-20-2012, 08:17 PM   #9
v8pony's Avatar
Yea they said the diagnostic was a 44$ charge, told em to just pull the code for me...came back and said "get ya self a new gas cap, it's got a small leak..bought one right there and boom light is off
2002 5spd GT
Old 12-20-2012, 08:22 PM   #10
I assume it was evap system small leak then or large leak yeah if it fixed it then its a common fix
Old 12-20-2012, 08:24 PM   #11
v8pony's Avatar
Yep no light..drove for about 50 miles too and still off...only thing is they only had gas caps with a lock on it, I'm in jersey where we cant pump our own gas, gonna be annoying to hand the attendant a key everytime .. Screw it tho I actually just left the key in the keyhole and there is still enough room to close the fuel door.
2002 5spd GT
Old 12-21-2012, 01:35 AM   #12
They're not too expensive if you decide to buy another one
http://www.latemodelrestoration.com/...g-Fuel-Gas-Cap
2001 GT
Old 12-21-2012, 01:42 AM   #13
Venomouz831's Avatar
Good got it solved
)02 Gt, Founder of WE2G
Old 12-21-2012, 04:47 AM   #14
I hope that fixed it ,,but if they cleared the codes for ya,,it takes a while to get that code,,the car has to be between 25 and 85 percent fuel level before the PCM will do a self test
mymustang is offline   Reply With Quote
Old 12-21-2012, 08:04 AM   #15
mine just came on too, so when my neighbor wakes up i will use his code reader.
gbmach1 is offline   Reply With Quote
Old 12-21-2012, 08:27 AM   #16
v8pony's Avatar
It's such a crap feeling right? Hopefully it's nothing like mine..hope for the best for ya
2002 5spd GT
Old 12-21-2012, 01:28 PM   #17
AgentOrange's Avatar
This. I have a small EVAP leak that isn't the gas cap. What a horrid system.
AgentOrange is offline   Reply With Quote
Old 12-21-2012, 01:33 PM   #18
Code C0430. Checked it ou said bank 2 on the x pipe. I just put catted xpipe on 2 weeks ago so I either have a leak, bad O2 sensor or my car does not like going from 4 cats to 2.
Old 12-21-2012, 06:52 PM   #19
It may be a cracked vacuum line to the evap. Sometimes its the vacuum on the passenger side near the firewall goin to the evap canister inside the fender. Id start looking for rotted lines
---------- Post added at 08:52 PM ---------- Previous post was at 08:50 PM ----------
Its quite possible since u went from 4 to 2 cats. A mil eliminator should do the trick also cliffyk has the website http://www.paladinmicro.com/pmicro.php where it shows to make ur own eliminators which is wat i did and they work marvelous might i add.
Old 12-21-2012, 07:34 PM   #20
Thanks for the help
04:42 AM
