low idle issue - Mustang Evolution
Old 05-19-2008, 05:25 AM   #1
low idle issue
hey ppl, im new to this forum but i have a 98' GT vert auto and i was driving on the freeway goin about 80mph then i coasted a little bit and when i hit the throttle it didnt respond at all as if the car had died but it didnt so eventually i made it off the freeway and when i was off it started working again but it was idling low at about 400 rpm and also rough it hesistates a little bit but other than that it drives normal...at first i thought it was the tranny becuz it wouldnt shift on the freeway but then it started working on the street...does anybody have an idea wat it could be
also the check engine light came on about a week ago and i ran it and it says the MAF sensor needs to be replaced and 2 o2 sensors, could that be the problem
Birdcoupe8998 is offline   Reply With Quote
Old 05-19-2008, 08:58 AM   #2
Black Vert's Avatar
Re: low idle issue
Most probably thats the problem. Replace those parts & see what happens
04 GT Convertible
Steeda CAI, Accufab 75mm TB/Plenum, Magnaflow Catted X pipe, Borla Catback, Steeda Tri Ax Shifter, Classic Light Bar, Federal SS595 245/45/17 Bullitt Rims
Black Vert is offline   Reply With Quote
Old 05-19-2008, 02:28 PM   #3
05RedDevil's Avatar
Send a message via AIM to 05RedDevil
Re: low idle issue
Yeah, fixing the known problems is good start. If that doesn't work then that is where the real fun begins.
Some show. Some go.
462 rwhp/ 446 ft-lbs
05RedDevil is offline   Reply With Quote
Looking for a set of low low ratio 7.5" gears PureVenom Pre-2005 V6 Mustang 4 08-13-2008 04:15 PM
03 Gt Pi Heads And Cams!!!! Low Miles/low Price alwaysthefinest Mustang Parts for Sale and Wanted 1 05-24-2007 05:17 PM
Odd idle issue today SpectorV Pre-2005 V6 Mustang 0 05-03-2005 11:42 AM
CAI installed... low idle problems... RedStang830 Pre-2005 V6 Mustang 16 08-03-2003 08:33 PM
10:58 AM
