Hissing Noise - Mustang Evolution
Old 12-19-2012, 07:14 PM   #1
JetLife 01GT's Avatar
So I have this hissing noise. I always notice the most when I first start it in my garage. I think I can hear it well in my garage because the sound bounces off the walls. Once I roll my windows up and I'm driving I don't notice it. I can't tell whether it's because it goes away once it warms up or cuz I can't hear it over my exhaust. Originally I thought the noise was maybe like an exhaust leak or something. About 6 weeks ago I swapped out the mid pipe with an o/r h(I had the noise before the new mid pipe so it's not the mid pipe). When I did I swapped it, I went an tightened up all of my catback to make sure it wasn't leaking. I just jacked my car up again last weekend and sprayed soapy water every where and I'm sure it's not leaking. No black soot anywhere either. When ppl her it they always say exhaust leak but in 99% sure that's not it. I've had the noise about 3 months now. The noise goes from a constant hiss to kind of choppy. I have a video. When I am on the drivers side it's constant and by the time I got to passenger side it was choppy again. The sound isn't coming from the engine. When you pop the hood you can tell its coming from the back of the engine and underneath somewhere. Sorry about the long essay but I just want you guys to know everything I know to better help diagnose my problem. Hopefully it's something easy. There's no CEL and it's drives, runs, and shifts fine. And the hiss has no direct impact on the idle(like making the idle jump or something). Don't mind my dusty engine lol. It needs a cleaning
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 12-19-2012, 07:32 PM   #2
98vertgt's Avatar
My car does the same thing! I personally think its a vacuum leak or something along those lines. I don't pay much attention since my car runs the same and isn't throwing any codes.
98vertgt is offline   Reply With Quote
Old 12-19-2012, 07:50 PM   #3
Wouldn't the noise be louder in the engine bay then? That would be a loud vacuum leak and seems like it'd have to be a pretty big leak to be that loud
2001 GT
Old 12-19-2012, 08:42 PM   #4
Speed_Mister's Avatar
Region: Arkansas
I'd just feel around sounds like air is being sucked in somewhere it shouldn't. I'd feel around houses and clamps air intake and stuff like that. Have you checked your air filter?
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-19-2012, 09:21 PM   #5
Mfore33's Avatar
Could be a crack in the rear of the intake manifold or intake gasket leak.
Old 12-19-2012, 09:25 PM   #6
Pretty sure air filter is on there good. I changed the filter around February this year. I'll take it off and check tomorrow. I've given the hoses a once over already. I will again tmrw when I check the filter. But the sound isn't coming from that area at all. In fact in the engine bay, you can barely hear the sound. But when you tuck your head underneath the car it's really loud. And it's the loudest right behind the front tires. Where the tranny bolts to the engine area-ish. I just don't know what the heck would make that type of sound from there.
---------- Post added at 08:25 PM ---------- Previous post was at 08:23 PM ----------
I'll check that out. How could I tell? I'll look for obvious cracks or something leaking. Is that about all I can do to see if it's cracked or leaking?
2001 GT
Old 12-19-2012, 11:01 PM   #7
Region: Arkansas
I agree with MFore33 it very well could be a crack in the manifolds.
Full Bolt Ons
370rwhp 470rwtq
Old 12-20-2012, 06:04 PM   #8
1996mustang's Avatar
use some carb cleaner and spray around and listen for a choke or rev up from the motor, we can rule out exhaust on the fact that u have fixed that issue first and seems to not be the problem at all, i would use the carb cleaner to find out from where it is coming from.
Old 12-02-2013, 08:40 AM   #9
heh jetlife,did you ever find what that hissing noise was ? i have that same exact problem.
vortech gt is offline   Reply With Quote
Old 12-02-2013, 04:06 PM   #10
Getn off's Avatar
Sounds like header gasket to me. Oem or aftermarket headers? Ever had them off? The right spot and it wont be noticeable under the hood, just under near front wheels btw.
Troy
Getn off is offline   Reply With Quote
Old 12-03-2013, 06:31 AM   #11
aftermarket,had them off about 2yrs ago for an engine swap.
Old 12-03-2013, 06:46 AM   #12
Liebert91stang's Avatar
+1 on the headers.the bolts back themselves out with the heat sometimes or gasket already worn out.i would say if it's vacuum leak the car wouldn't idle or run without a miss
Liebert91stang is offline   Reply With Quote
Old 12-03-2013, 06:50 AM   #13
not the bolts,i have studs,its probally a gasket or crack header.
wish jetlife would chime in before i go tearing into the car.
Old 12-03-2013, 10:58 AM   #14
No I never figured out the problem. The noise kind of disappeared over time as I took various things apart. I looked for a vaccum leak and found a small one but I still had the noise after I fixed it. I checked intake manifold and it wasn't that. So I kinda gave up on it. Since this post the only things I've messed with that have air going through them are the cai and I had my exhaust on and off a couple different times. I'm pretty sure the noise is gone. I think I hear it sometimes but really faint. I think it was something to do with my exhaust but I'm not sure. Sorry I didn't get on here sooner man. Best of luck
2001 GT
Old 12-03-2013, 12:03 PM   #15
thanks bro for checking in,going to have to pull the exhaust and take a look
11:36 AM
