Air bag and battery light 2000 gr - Mustang Evolution
Old 12-20-2012, 12:13 PM   #1
DeVellis's Avatar
What causes these two dashboard lights to come on?
DeVellis is offline   Reply With Quote
Old 12-20-2012, 02:21 PM   #2
My battery light cuts on and off idk why it's been like this forever. Hopefully someone can answer this.
Ryan7racin is offline   Reply With Quote
Old 12-20-2012, 05:54 PM   #3
1996mustang's Avatar
for a battery the battery or an alternator problem will set off the light on the dash. as for the air bag it can be a sensor for the air bag system, or a blown or deleted air bag, bad air bag module or clockspring can set off the air bag light. also on the air bag it can be a fuse or the air bag sensor thats on the steering wheel.
Old 12-20-2012, 07:28 PM   #4
DeVellis's Avatar
Yeah same thing here it was on and then it stayed on for like ten mins then cut off.
Old 12-20-2012, 08:30 PM   #5
I would check the wires for corrosion or to see if they are loose that could also cause it to show the battery symbol
04:43 AM
