Engine didferences? - Mustang Evolution
Old 12-20-2012, 05:48 PM   #1
Polar Bear's Avatar
Region: Asia
Engine didferences?
Are there any significant differences between 96-98 GT engines? Specifically interested in knowing in regards to throttle body and manifold area.
Steve
Polar Bear is offline   Reply With Quote
Old 12-20-2012, 06:26 PM   #2
98vertgt's Avatar
98s have better flowing manifolds. That's where the extra 10hp come from
98vertgt is offline   Reply With Quote
Old 12-20-2012, 06:40 PM   #3
1996mustang's Avatar
i dont see how the 98 has a better manifold since both 96 and 98 are non pi motors, but then again it is ford however lol. however just grab a f150 throttle body since its 70mm from stock if u lookin for a quick cheap upgrade. as to the manifold im really not sure how 10hp more is possible since they were rated at the same hp. but once again im no rocket scientist lol so the more i learn and get schooled the better for me. as to plenum if u use a crown vic plenum would help since its got a elbow design or f150 plenum. and yes it will fit and work and will bolt right on perfectly. but im sure someone else will chime in.
Old 12-20-2012, 07:49 PM   #4
Polar Bear's Avatar
Region: Asia
Would the style (configuration) of a plenum spacer differ from a 97 to 98 or 99? Assuming stock everything else aside from CAI.
Steve
Old 12-20-2012, 07:56 PM   #5
jdavis96gt's Avatar
Region: West Virgina
Don't know what the difference is but 96 is 215hp and 98 is 225.
Old 12-20-2012, 08:16 PM   #6
Polar Bear's Avatar
Region: Asia
And I've every number in between those two for a 97. Lol
Steve
Old 12-20-2012, 08:19 PM   #7
98vertgt's Avatar
Exhaust manifolds* my bad
Old 12-20-2012, 09:28 PM   #8
Exhaust i can see it being it yes id agree. As for a spacer no different configuration in 99-04 plenum or throttle body
Old 12-20-2012, 09:59 PM   #9
Polar Bear's Avatar
Region: Asia
The question was difference between a 97 and 98. Sorry if I confused it. I have a 97.
Steve
Old 12-20-2012, 10:01 PM   #10
I believe it would be the same but ill wait for someone who did research chime in
Old 12-20-2012, 10:03 PM   #11
Polar Bear's Avatar
Region: Asia
You have a 96 right? Aren't all 3 the same? 96-98
Steve
Old 12-20-2012, 10:10 PM   #12
Mines different i have pi heads lol however in all honesty from 96 to 97 there were changes mad such as radiator and radiator stays. Power wise not any difference however in 98 ford around mid year started with electronic dash milage display like the 99-04 and possibly headers or exhaust difference.
Old 12-20-2012, 11:46 PM   #13
Polar Bear's Avatar
Region: Asia
Knowledge I'm happy to have now. Thanks.
Steve
Old 12-22-2012, 02:34 AM   #14
Polar Bear's Avatar
Region: Asia
Well I guess the difference in placement of brackets was significant enough. I couldn't install the Poweraid spacer into my car. The throttle cable was pushing against another surface and wouldn't allow the throttle to close properly. Damn I wanted this spacer to work.
Steve
01:27 AM
