Bad Fuel pump? - Mustang Evolution
Old 12-22-2012, 06:21 PM   #1
BeasGT's Avatar
Bad Fuel pump?
When I'm driving my GT the car feels like it is going to shut off. I was told it could be the fuel pump. Anyone have the same problem?
BeasGT is offline   Reply With Quote
Old 12-22-2012, 06:28 PM   #2
schmitty426's Avatar
Yeah but once I shut it off never started again could be a vaccum leak somewhere
schmitty426 is offline   Reply With Quote
Old 12-22-2012, 06:30 PM   #3
BeasGT's Avatar
Mine starts and runs.
It only happens some times.
Old 12-22-2012, 06:31 PM   #4
Dose this occur as u hit the gas or let off
Old 12-22-2012, 06:34 PM   #5
BeasGT's Avatar
When I hit it. After the 1st rpm.
& as soon as I let it off it runs normal
Old 12-22-2012, 06:36 PM   #6
taylor98gt's Avatar
Mine does the same thing, I changed coils and wires and its a lot better but still not 100% I'm really confused as to what else to check
taylor98gt is offline   Reply With Quote
Old 12-22-2012, 06:37 PM   #7
I don't think its your fuel pump cuz when they go the jus go no warning I've never heard of that happening sorry bud I'm sure someone will have an answer for ya.. maybe its your plugs and wires??
Old 12-22-2012, 06:47 PM   #8
Mathew r Wright's Avatar
No codes???
Mathew r Wright is offline   Reply With Quote
Old 12-22-2012, 06:52 PM   #9
Originally Posted by Mathew r Wright View Post
No codes???
Could have a bad connection on the fuel pump mine did before it shorted out...
Does it drive like its hesitant and gonna run out of gas?
Old 12-22-2012, 07:08 PM   #10
BeasGT's Avatar
Yes exactly like that!
Old 12-22-2012, 07:49 PM   #11
Coreyw428's Avatar
Region: Arkansas
Just because no one else suggested it... When is the last time you changed your fuel filter? Or have you filled up at a new gas station that you usually don't fill up at
Coreyw428 is offline   Reply With Quote
Old 12-22-2012, 07:54 PM   #12
BeasGT's Avatar
I changed it when I rebuilt the engine.
Which was about a year ago.
Old 12-22-2012, 08:13 PM   #13
Try coils man I'm telling you these mustangs have a lot of the same symptoms. Try both really. I just got over this issue. I would just go through standard procedure and check volt reference to the pump also.
---------- Post added at 09:13 PM ---------- Previous post was at 09:12 PM ----------
Oh yah change it now!!!
Old 12-22-2012, 09:34 PM   #14
Coreyw428's Avatar
Region: Arkansas
If it's been a year, I'd go ahead and change it... Don't take but 15 min, if even that and if it doesn't help then move to the coils. I say that cause my car done somethin similar to that when I first got it, and it ended up bein fuel filter.. But I don't have individual coils, I have packs so I could be wrong. Just givin out my 2 cents for the day lol
Old 12-22-2012, 09:35 PM   #15
BeasGT's Avatar
If it's been a year, I'd go ahead and change it... Don't take but 15 min, if even that and if it doesn't help then move to the coils. I say that cause my car done somethin similar to that when I first got it... But I don't have individual coils, I have packs
I think ima try the coils
Old 12-22-2012, 09:36 PM   #16
Can't agree more
---------- Post added at 10:36 PM ---------- Previous post was at 10:35 PM ----------
Filter too man they really don't last long...
Old 12-22-2012, 09:38 PM   #17
BeasGT's Avatar
Thank you guys.
Ill get to it this week.
Old 12-24-2012, 06:32 AM   #18
Mfore33's Avatar
I know people don't like the cheap jegs coils. But i bought one for 17 bucks just to use as a test coil. That way I've got a cheap one in the trunk for emergency and to test for bad coils. Then if I find one I get a factory ford for the fix.
Old 12-24-2012, 11:42 AM   #19
+1 that's a good idea...
Old 12-24-2012, 12:29 PM   #20
e.grant@ymail.c's Avatar
Region: West Virgina
Yes I had a fuel pump issue 1994 cobra. It will let u know if it is bad
e.grant@ymail.c is offline   Reply With Quote
Old 12-24-2012, 03:13 PM   #21
Voltage258's Avatar
Region: Utah
I don't know. I had a fuel pump going bad I'm my old jeep it did not run like it was dieing but when I would floor it the rpms would go up and scream but it would not accelerate the once I replaced the pump it never did it again..... But I would definitely change everything everyone suggested first because a fuel pump is probably the most expensive..
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 12-24-2012, 03:46 PM   #22
That's weird... Cars are definitely a mystery lol and yes fuel pump is the most expensive.. just had mine go about 2 months ago and it was under warranty thank god... and my dealership gave me a recipet for my 100 deductible and the total was $$1,075!!!
Old 12-24-2012, 08:34 PM   #23
Voltage258's Avatar
Region: Utah
Holy mother that is a ton. I guess that is what it is if you go OEM pump and installed at a dealer. I think my jeep cost me $300-$400.
Old 12-24-2012, 09:16 PM   #24
Hell yeah it was super expensive but super glad I was under warranty
Old 01-03-2013, 03:26 AM   #25
Joe Jeezy's Avatar
Won't let me message you, says u have to erase messages
Joe Jeezy is offline   Reply With Quote
Old 01-03-2013, 07:13 PM   #26
Fastfive_ogt's Avatar
Try unplugging your maf and see if the problem goes away.
Fastfive_ogt is offline   Reply With Quote
11:10 PM
