heater hose - Mustang Evolution
Old 12-23-2012, 07:08 PM   #1
heater hose
What is the inlet and outlet. On the core and the hoses?
Cdbformula is offline   Reply With Quote
Old 12-23-2012, 08:35 PM   #2
cliffyk's Avatar
The hose from the vertical nipple on the intake manifold is the inlet, the one that passes through the valley between the cylinder banks, to the back of the water pump cavity is the outlet...
Old 12-23-2012, 08:42 PM   #3
Which nipple is the inlet and outlet on the heater core?
Old 12-23-2012, 10:16 PM   #4
1996mustang's Avatar
Follow the hoses. Cliffy already pointed out the inlet for u basically just follow it to the firewall and that would be the inlet nipple.....and so on and so forth
Old 12-24-2012, 07:01 AM   #5
I would have followed the hose but when i got the car the core was bypassed. I changed it out and just wanted to double check the hose location. This isnt a project i wanna do again. Does it really matter on the core if you hook the inlet hose to the outlet nipple?
Old 12-24-2012, 07:27 AM   #6
cliffyk's Avatar
The heater core input is the one nearest the passenger side IIRC. Here's a cooling system schematic FWIW:
Old 12-24-2012, 08:24 AM   #7
Thanks cliffy. I got it all together so far so good.
Old 12-24-2012, 09:13 AM   #8
cliffyk's Avatar
Cool, I did not realise you had nothing to go by...
Old 12-24-2012, 11:17 AM   #9
Me either i thought u had the hoses connected
« Pro-M | Trac loc »
08:24 AM
