Pro install - Mustang Evolution
Old 12-25-2012, 05:12 PM   #1
Doe_Rae_mi's Avatar
Pro install
How much would it cost for sum1 to install some lowering springs. I need a guestimate
Old 12-25-2012, 05:18 PM   #2
Region: Arkansas
Assume $90-$100/hour labor and its about a 2-3 hour job. $200-$275 sounds about normal.
Honestly, springs are one of the easiest DIY jobs aside from basic mods. Grab some jack stands and a spring compressor for $150 or so and get experience plus a stance.
BackPressure is offline   Reply With Quote
Old 12-25-2012, 05:50 PM   #3
Doe_Rae_mi's Avatar
I'm really scared to do these myself.
Old 12-25-2012, 06:12 PM   #4
Venomouz831's Avatar
Super easy really a few bolts, borrow a compressor from auto zone and you're good. Basic hand tools
)02 Gt, Founder of WE2G
Old 12-25-2012, 06:27 PM   #5
Doe_Rae_mi's Avatar
What would I use the compressor for?
Old 12-25-2012, 08:00 PM   #6
1996v6stang's Avatar
I dont even use a compressor. Its pretty easy.
1996v6stang is offline   Reply With Quote
Old 12-25-2012, 08:55 PM   #7
Matticus's Avatar
Compressor for rears, don't touch the fronts with one. It will cause nothing but pain and frustration. For front springs just unplug the abs line and drop the a-arm, the front springs will pretty much slide out with some wiggling.
Matticus is offline   Reply With Quote
Old 12-25-2012, 08:57 PM   #8
Do u need it for the rear?
Old 12-26-2012, 07:04 AM   #9
Matticus's Avatar
I'm not sure if there's another method, but I know the compressors worked good for the rears when I did mine mainly because the spring rates aren't as stiff on the rears. You can rent the compressors at most autozones. You pay a deposit and then you get it back when you bring the compressor back.
Old 12-26-2012, 07:09 AM   #10
1lowGT's Avatar
+1 i Didn't use them either on the new edge but s197 compressor is needed for sure they shot out at 10000mph lol
Old 12-26-2012, 10:56 AM   #11
Lol ill keep a note of that
02:40 PM
