O/r x - Mustang Evolution
Old 12-25-2012, 10:14 PM   #1
Trbluebullitt's Avatar
O/r x
Just bought a o/r x pipe from AM I kno some stuff about working on cars. Changing oil brake pads rotors spark plugs stuff like that will it be that hard for me to install? By myself I have a lift.
Trbluebullitt is offline   Reply With Quote
Old 12-25-2012, 10:22 PM   #2
Xtrosity's Avatar
With a lift it should be easy. One of the passenger side bolts on the manifold and the driver o2 sensor will give a good fight, other than that it's pretty easy.
Xtrosity is offline   Reply With Quote
Old 12-25-2012, 10:22 PM   #3
Thanks man!
Old 12-25-2012, 10:26 PM   #4
Xtrosity's Avatar
No problem. Keep us updated and a sound clip when your done. Bet it'll sound awesome.
Old 12-25-2012, 10:27 PM   #5
Venomouz831's Avatar
Preety easy man. Basic hand tools and jacks with some pb blaster
)02 Gt, Founder of WE2G
Old 12-25-2012, 10:28 PM   #6
pb blaster?
Old 12-25-2012, 10:32 PM   #7
Xtrosity's Avatar
Get it at autozone or some place similar. Helps break the bolts loose after sitting for all these years.
Old 12-25-2012, 10:35 PM   #8
Yes it will make you're time easier and quicker
Old 12-26-2012, 12:09 AM   #9
Lorraine's driver
ab_mach1's Avatar
IMO, the hardest part was unplugging the drivers side O2 sensor. On the passenger side, at the manifold, it sucked having a loose universal joint socket extension. Every time you would get the socket over to the nuts, gravity would make my socket drop and point down. Not a show stopper, just a PITA. When putting on the o/r mid pipe, I found it easier to start the end toward the back of the car first, then connect to the manifolds. After a few days, I would jack it up and make sure everything is still tight. Good luck and let us know how it goes.
Instagram: @ab_mach1
Old 12-26-2012, 07:04 AM   #10
1lowGT's Avatar
I started at the manifolds bolted them turned the nut a few times and connected to catback bolted the cat back down tight then went to the manifold ms and tightened them last.
Old 12-26-2012, 07:08 AM   #11
Matticus's Avatar
Don't forget to unplug the battery, it would be easy and very unfortunate if you got against the starter while you're under there. Pb blaster all
The bolts, then start from the back and work your way up. Pretty much what the others posted. Good luck and enjoy the new exhaust!
Matticus is offline   Reply With Quote
Old 12-26-2012, 07:11 AM   #12
Lorraine's driver
ab_mach1's Avatar
^Good tip!
Old 12-27-2012, 06:25 PM   #13
03fastblack's Avatar
Good luck!
03fastblack is offline   Reply With Quote
Old 01-04-2013, 11:37 PM   #14
Omg! They sound soooooo mean! I fell in love all over again
Old 01-04-2013, 11:54 PM   #15
Lorraine's driver
ab_mach1's Avatar
You sir, need to post a link to a video so we can all enjoy.
Old 01-05-2013, 12:29 AM   #16
Will do!
Old 01-05-2013, 08:36 AM   #17
1lowGT's Avatar
What catback you got?
Old 01-05-2013, 06:52 PM   #18
Bbk into flowmasters
Old 01-06-2013, 10:25 AM   #19
1lowGT's Avatar
What series
Old 01-06-2013, 10:41 AM   #20
RUNNWLD's Avatar
Region: Utah
I don't wanna jack the thread but I don'twanna make one for a simple question. Will any brand of o/r h pipe bolt up to my slp lm1 cat back?
RUNNWLD is offline   Reply With Quote
Old 01-06-2013, 10:46 AM   #21
Yea people mix and match combos all the time
Old 01-06-2013, 10:51 AM   #22
RUNNWLD's Avatar
Region: Utah
Okay sweet you think the pypes o/r h will be okay then? I just ordered my tuner so when I get paid again I'm gunna buy my midpipe.
Old 01-06-2013, 11:01 AM   #23
1lowGT's Avatar
Yes pypes bolt up to slp catback. I recently done that an it's awesome!
Old 01-06-2013, 11:25 AM   #24
RUNNWLD's Avatar
Region: Utah
Okay sweet is it loud with the slp lm1? Is it an pypes o/r h or the x?
Old 01-06-2013, 12:54 PM   #25
1lowGT's Avatar
http://youtu.be/9UKx6v7JhGI
Here's mine loudmouths with pypes o/r h
Old 01-06-2013, 12:58 PM   #26
1low you need to hear jr's car.
Old 01-06-2013, 01:00 PM   #27
1lowGT's Avatar
Did he get a new turbo back?
Old 01-06-2013, 01:33 PM   #28
Lorraine's driver
ab_mach1's Avatar
Sounds great!
Old 01-06-2013, 01:58 PM   #29
RUNNWLD's Avatar
Region: Utah
That sounds good!! Is it way loud in person?
Old 01-06-2013, 04:24 PM   #30
What series
44s I believe
Old 01-06-2013, 06:10 PM   #31
1lowGT's Avatar
Sounds great!
Thanks!
---------- Post added at 07:10 PM ---------- Previous post was at 07:08 PM ----------
Yeah it's loud!
Old 01-06-2013, 09:20 PM   #32
RUNNWLD's Avatar
Region: Utah
A lot louder than just the catback?
Old 01-07-2013, 07:09 AM   #33
1lowGT's Avatar
Way louder.
---------- Post added at 08:09 AM ---------- Previous post was at 08:08 AM ----------
http://youtu.be/pjdscj3KwLQ
Just catback
Old 01-07-2013, 03:50 PM   #34
RUNNWLD's Avatar
Region: Utah
Okay sweet I'm goin to be ordering the pypes offroad h next week. Do i need 02 sensors or extensions or do I just need the pipe?
Old 01-07-2013, 04:05 PM   #35
1lowGT's Avatar
What year is your car?
03:11 AM
