Scared to lower it - Mustang Evolution
Old 12-26-2012, 01:43 PM   #1
Doe_Rae_mi's Avatar
I'm finally about to purchase the last piece to the my car...it's taken me 2 years to get it here and it will be my last cosmetic mod...and I am scared to death to try and lower it myself..people say it's simple but I'm very scared that I will mess something up...I'm 18 with a little bit of knowledge, an online tutorial I found,and my grandpa that used to fix cars for a living... Will I be able to do this?
Old 12-26-2012, 01:53 PM   #2
98vertgt's Avatar
oh yeah! its super easy. i did my car all by myself but an extra hand helps. dont be scared! just remember you need to have it aligned a couple days after you lower it after the springs settle
98vertgt is offline   Reply With Quote
Old 12-26-2012, 01:59 PM   #3
Doe_Rae_mi's Avatar
What will happen if I don't align it? Lol
Old 12-26-2012, 02:00 PM   #4
Black on Boss's Avatar
I would at least have a friend help. I personally would have it professionally installed.
---------- Post added at 04:00 PM ---------- Previous post was at 03:59 PM ----------
Your tires will wear super fast
Old 12-26-2012, 02:01 PM   #5
Doe_Rae_mi's Avatar
Oh lord I just got new tires ...would I take it to a suspension shop to have it aligned? And what are they aligning?
Old 12-26-2012, 02:04 PM   #6
Your tires and yea a local alignment shop will do it. It ain't that expensive. As long as all your suspension is good.
Old 12-26-2012, 02:04 PM   #7
1lowGT's Avatar
Do it yourself it's simple saves money too
Old 12-26-2012, 02:05 PM   #8
And BTW your car don't look green no more
Old 12-26-2012, 02:06 PM   #9
Matticus's Avatar
How much of a drop is it? 2 inches or more and I would definitely recommend caster camber plates. Mine is dropped 1.5 inches all around and I have had no extra tire ware. An alignment is always a good idea, but if it's less than 2 inches you should be okay regardless.
Matticus is offline   Reply With Quote
Old 12-26-2012, 02:11 PM   #10
Doe_Rae_mi's Avatar
Haha! Thank you for your help
---------- Post added at 04:11 PM ---------- Previous post was at 04:11 PM ----------
Mine will be 1.7 in the front and 1.5 in the back
Old 12-26-2012, 02:15 PM   #11
Matticus's Avatar
I think you'll be okay, an alignment certainly won't hurt though if you want to go ahead. Also, to help the springs compress to the correct height, I'd keep some weight in your trunk for a few days. Something like a 24 pack of water bottles or something that has some weight.
Old 12-26-2012, 02:28 PM   #12
1slosix's Avatar
I lowered mine the other day by myself no spring compressor in 2 hours...sr performance springs from AM. Ive now lowered 5 stangs and its always a cake walk. I wait two weeks till an alignment though.
carving corners like a boss
Old 12-26-2012, 02:29 PM   #13
Doe_Rae_mi's Avatar
Thank you! I'm deffinetly ganna align them if it helps save tread...ill be ordering my springs tonight
Old 12-26-2012, 02:35 PM   #14
Doe_Rae_mi's Avatar
How much do u think it will cost? Just a estimate?
Old 12-26-2012, 02:41 PM   #15
98vertgt's Avatar
50-80 depending on where you go
Old 12-26-2012, 02:44 PM   #16
Doe_Rae_mi's Avatar
That's not bad at all actually!
Old 12-26-2012, 02:45 PM   #17
runvsofthisbull's Avatar
$70 ish for a alignment. You don't need caster/camber plates but they are always a good idea to help dial it in.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 12-26-2012, 02:48 PM   #18
BeasGT's Avatar
My car is lowered more from the back than it Is from the front.
Anyone know why that is?
BeasGT is offline   Reply With Quote
Old 12-26-2012, 02:49 PM   #19
Doe_Rae_mi's Avatar
You could have some extra weight in the trunk?
Old 12-26-2012, 02:50 PM   #20
1lowGT's Avatar
Did you use the right springs? Lol.
Old 12-26-2012, 02:53 PM   #21
Is your front suspension stock? I have tubular a arms and a k member and my front is slightly higher also but that's why. How long have u had it lowered? Takes some time for the springs to settle.
Old 12-26-2012, 03:12 PM   #22
Doe_Rae_mi's Avatar
I'm about to order my springs but I got a quick question...when I'm installing these how am I supposed to know which springs go in the front and which go in the back? The front will have a bigger drop so I guess the shortest ones will go in the front?
Old 12-26-2012, 03:15 PM   #23
BeasGT's Avatar
No lol my truck is empty lol just the spare
Old 12-26-2012, 03:15 PM   #24
98vertgt's Avatar
They'll say front and rear
Old 12-26-2012, 03:16 PM   #25
BeasGT's Avatar
I'm lowered on eibach sport lines.
I bought the car lowered about a year ago.
Old 12-26-2012, 03:17 PM   #26
Horseplay's Avatar
did the alignment without the plates help out ?
Low2v
Old 12-26-2012, 03:20 PM   #27
Doe_Rae_mi's Avatar
What the heck is a snubber lol
Old 12-26-2012, 03:20 PM   #28
1lowGT's Avatar
Rear will be wider
Old 12-26-2012, 03:40 PM   #29
Doe_Rae_mi's Avatar
I want my car to dip just a little bit which is why I am buying these springs...the front wheel gap on my car seems to be bigger than the back wheel gap...I'm scared that after buying and installing these springs the back of my car will sill be lower
ID:	82761   Click image for larger version
Old 12-26-2012, 03:42 PM   #30
1lowGT's Avatar
What springs you going with. You can leave your stock isolators on the rear and take them off in the front
Old 12-26-2012, 03:43 PM   #31
Doe_Rae_mi's Avatar
The eibach sportlines...it's a 1.7 inch drop in the front and 1.5 in the back. And are u saying to not have isolaters at all in the front?
Old 12-26-2012, 03:45 PM   #32
1lowGT's Avatar
When you take the stock springs off take the front isolators off and leave the back.
Old 12-26-2012, 03:50 PM   #33
Doe_Rae_mi's Avatar
Is it ok to not have isolators?
Old 12-26-2012, 03:52 PM   #34
1lowGT's Avatar
Yes it's fine to run without them.
Old 12-26-2012, 03:55 PM   #35
Doe_Rae_mi's Avatar
What if I didn't even put springs in the back lol
06:21 PM
