Sway bars! - Mustang Evolution
Old 12-26-2012, 02:57 PM   #1
98vertgt's Avatar
Sway bars!
Just ordered my eibach front and rear sway bars from am! Anyone have any tips for installation or have them and love them?
98vertgt is offline   Reply With Quote
Old 12-26-2012, 03:49 PM   #2
1lowGT's Avatar
Nice. Good luck with the install. I think it should be pretty straight forward. But I have no idea.
Old 12-26-2012, 04:04 PM   #3
sLbxO143's Avatar
Let me know when you get them in & how they work. Looking to buy the same ones shortly, good luck!
sLbxO143 is offline   Reply With Quote
Old 12-26-2012, 04:42 PM   #4
1slosix's Avatar
if you can lift it off the ground you'll have a pretty easy swap...the rear will swap in under 5 mins as long as the bolts aren't siezed...the front however will take a bit longer...i'd have an hour to spare at least just in case lol
carving corners like a boss
Old 12-26-2012, 05:03 PM   #5
98vertgt's Avatar
Yeah I know the rear will be easy I'm just worried about the front. Thanks for the input!
Old 12-26-2012, 05:20 PM   #6
1slosix's Avatar
does it come with all new bushings?
Old 12-26-2012, 05:33 PM   #7
98vertgt's Avatar
Yep!
Old 12-27-2012, 12:26 AM   #8
Slow03GT's Avatar
I'm pondering upgrading my sway bars soon as well. If anyone knows of a good install write up they can share it would be appreciated.
03 Dark Shadow Grey GT: 03 Cobra Brake Upgrade, H&R Super Sport Springs, Magnaflow Magnapack Catback, Anthracite FR500s with Continental ExtremeContact DW tires all around, Steeda Tri-ax, Maximum Motorsports Full Length Subframe Connectors, plus much more...
Slow03GT is offline   Reply With Quote
Old 12-27-2012, 12:51 AM   #9
98vertgt's Avatar
American muscle has one on their website. If you click the installation tab on the product page it should say where it is
Old 01-04-2013, 12:19 AM   #10
Slow03GT's Avatar
Thanks, I will have to check it out.
Old 01-05-2013, 08:07 AM   #11
onesickstang01's Avatar
Swar bar end links on front are the worst. Use your stock end link rods and swap the new bushings on to those. The eibach supplied rods are too short and almost impossible to get on
onesickstang01 is offline   Reply With Quote
Old 01-05-2013, 08:15 AM   #12
I'm usually one to do things myself but those front end links; stock or those supplied by eibach made the front install damn near impossible; especially when using the new bushings. I had to give up and bring it to my local mechanic. I was pissed bc I hate paying for someone else's labor but when all was said and done the new front and rear bars made a world of difference.
delff128 is offline   Reply With Quote
Old 01-05-2013, 09:00 AM   #13
Mzilla's Avatar
I use steeda blue light weight sway bars. I also have energy suspensions shortened end links. If your car is lowered then I highly recommend using the shortened end links to place the sway bar in proper geometry with your control arms to get the most from your new sway bar. Reusing the stock end links defeat some of the purpose of the sway bar
Mzilla is offline   Reply With Quote
Old 01-05-2013, 09:16 AM   #14
The rods that come with eibachs are shortened. If you use the center spacer from the eibach kit you get the shortened end link but use the original threaded bolt so you have an easier time threading the nut on the end. The bolt supplied with eibachs just isnt long enough to thread on the nut easily
Old 01-05-2013, 09:51 AM   #15
98vertgt's Avatar
I havent posted in a couple days but i put them on wednesday and they make a world of difference, it feels like a different car. but yes the end links were a pain but i got them on and i actually think they might've lowered the car just a little bit. i had just as much trouble with the rear sway bar with the stock clips going on the new one so i just bought some 3/8 bolts and nuts and made it easy.
» Members Mustangs
JM
blue
Pickup
CobraGirl
Add your Mustang
06:18 PM
