Dash speedometer trick? - Mustang Evolution
Old 12-29-2012, 12:05 AM   #1
MineralGrayGT's Avatar
Region: Wyoming
So theres this kid here who did something like put his car on accessories then held in the reset button then started his car and where his digital miles on it changed and he could see his MPGs, digital speed, and all kinds of stuff. Anyone else know of this trick and can tell me if im doing it wrong cause i can never do it haha
MineralGrayGT is offline   Reply With Quote
Old 12-29-2012, 02:41 AM   #2
Mfore33's Avatar
Put key in ignition. Press and hold trip rest button and turn key to run. Keep holding trip reset until the gauges all peg out to the right then let off trip reset. This lets you into diagnostic mode and other cool stuff. You can still start car and the new mode will stay until car is turned off. Press trip reset again to go to next menu item on LCD
Old 12-29-2012, 06:59 AM   #3
Horseplay's Avatar
very nice i didnt know we could check our mpg's niceee! im going to try this right now
Low2v
Old 12-29-2012, 07:06 AM   #4
jdavis96gt's Avatar
Region: West Virgina
Does it work for a 96? Or is my technology too old lol?
Old 12-29-2012, 07:16 AM   #5
No mpg... You can check engine codes and several other variables. I've used it to diagnose alternator issues by watching voltage numbers
---------- Post added at 08:16 AM ---------- Previous post was at 08:15 AM ----------
Nope, you need the digital odometer. It works on my 07 focus as well
Old 12-29-2012, 07:37 AM   #6
Horseplay's Avatar
**** ! is there a way i can see my mpg?
Low2v
Old 12-29-2012, 08:34 AM   #7
Calculator?
Old 12-29-2012, 08:56 AM   #8
Horseplay's Avatar
Calculator?
how do i calculate the mpg's?
Low2v
Old 12-29-2012, 09:05 AM   #9
Eturner's Avatar
Fill your car up, drive X amount of miles then fill it back up again. Divide your miles driven by the amount of gas used/the amount it took to fill it back up the 2nd time. Do this several times and you can average out your mileage pretty good.
Old 12-29-2012, 09:09 AM   #10
Yupp. I use www.fuelly.com to track and see trends. For best results use the same pump at the same time of day and don't top it off
Old 12-29-2012, 10:27 AM   #11
cliffyk's Avatar
The instrument cluster diagnostic mode does not display powertrain diagnostic codes, more about what it does do here...
Old 12-29-2012, 10:10 PM   #12
Region: Wyoming
Mine wont ever say "test"
Old 12-30-2012, 10:03 AM   #13
cliffyk's Avatar
Then it is broken, or you are perhaps not performing the start-up ritual correctly--it is sort one of those "knacky" things to do, one where once you get the knack it's easy...
Old 12-30-2012, 01:56 PM   #14
If you say so...
Old 12-30-2012, 02:00 PM   #15
cliffyk's Avatar
If you say so...
Actually Ford says so--did you read the document?
Old 12-30-2012, 02:02 PM   #16
No, i've used it to read codes before.
Old 12-30-2012, 02:34 PM   #17
cliffyk's Avatar
It displays "codes", however it does not display any but one Pxxxx (Powertrain) code. It displays only a sub-set of Bxxxx (Body) and Cxxxx (Chassis) trouble codes.
Had you read the document you would know that...
11:58 PM
