2v and 4v differences - Mustang Evolution
Old 12-29-2012, 04:54 PM   #1
02StangGT's Avatar
What is the difference between a 2v and a 4v I am new here
02StangGT is offline   Reply With Quote
Old 12-29-2012, 04:58 PM   #2
98vertgt's Avatar
Each cylinder has 4 valves instead of 2
98vertgt is offline   Reply With Quote
Old 12-29-2012, 05:00 PM   #3
02StangGT's Avatar
Oh okay thanks
Old 12-29-2012, 05:04 PM   #4
98vertgt's Avatar
Oh okay thanks
No problem! And welcome!
Old 12-29-2012, 06:08 PM   #5
Mezmer's Avatar
Also different heads, two more camshafts, and different compression ratio. The 4v also has the ability to rev higher and has more top end where the 2v is more built for low end. IMO 4v are better.
2004 Mustang Mach 1 - SY
Exhaust - Wanna be Flomasters...
JLT Ram Air Intake
SR Performance Short Throw Shifter
Mezmer is offline   Reply With Quote
Old 12-29-2012, 06:54 PM   #6
98vertgt's Avatar
And they respond better to bolt ons
Old 01-01-2013, 06:07 PM   #7
02StangGT's Avatar
How would I change my car to 4v?
Old 01-01-2013, 06:14 PM   #8
JetLife 01GT's Avatar
Motor swap is easiest
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 01-01-2013, 06:20 PM   #9
02StangGT's Avatar
And I'm guessing the 4v is better then the 2?
Old 01-01-2013, 06:27 PM   #10
It flows better and produces more horses. Depends on how you look at it. Some ppl love their 2v and think its better. And same goes for 4v owners. But mod for mod you'll get more out of a 4v and a 4v produces more hp stock. 4v have 4 valves and dual overhead cams. Compared 2v with 2 valves and single overhead cam. But that doesn't mean you can get just as much power out of a 2v
2001 GT
Old 01-01-2013, 07:37 PM   #11
Horseplay's Avatar
well said +100
Low2v
Old 01-01-2013, 09:24 PM   #12
Rosco's Avatar
4v also sound different than 2v.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 01-02-2013, 04:21 AM   #13
2003mustangGT's Avatar
Alright but to go from a 2v to a 4v how hard would it be? Like say you have a teksid block fully built bottom end with no timing cover heads cams any of that. What all do you need to make it a 4v?
2003mustangGT is offline   Reply With Quote
Old 01-02-2013, 06:25 AM   #14
Horseplay's Avatar
buy a 4v engine from a mach one or from a cobra.
Low2v
Old 01-02-2013, 06:53 AM   #15
Haro's Avatar
Take it from someone who learned the hard way. If you have the chance to get a Cobra/Mach 1 do it. I had my GT and loved it but after 400-420hp its only a matter of time until you have to build the engine. It takes WAY WAY more cash to make power through a 2v like a 4v does. People will say Cams cost more on 4v because your paying for 4 of them instead of 2 but cams do not net you the power thats worth the cost unless your above 800hp and even then the stock cams hold up just fine. IMO sense I have done it, find a 4v car and save yourself the headache unless you really want to do a swap. If your gonna do a swap like that as well I suggest you find something worth swapping like a Termi engine or a 5.4L 4v that you can build. Hope it helps ~Haro
Haro is offline   Reply With Quote
Old 01-02-2013, 07:23 AM   #16
Coreyw428's Avatar
Region: Arkansas
Find a set of 4v heads fully assembled... 03-04 cobra heads would be the best if your goin fi... They have awesome cams from the factory. Then order timing chains for a 4valve motor. Get a 4valve intake... And get a timing cover for a 98 to 01 cobra or 1 off a Mach 1...
Coreyw428 is offline   Reply With Quote
Old 01-02-2013, 09:35 AM   #17
95v686gt's Avatar
96 to 98 cobra had the best cams. And the b heads love FI cause of the twin intake ports. Talk to 32vnomad. He has dealership and service manuals and can give you the specs on everything 4v!
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 01-02-2013, 04:31 PM   #18
Coreyw428's Avatar
Region: Arkansas
C port are the best... If 96 to 98 was the best way to go then you would see more ppl doin a b port head swap.. And 96 to 98 might be for a n/a cam.... But 03/04 was made for fi, all they had in mind when ford had them made, well that and drive ability and longevity
08:18 AM
