Transmission type - Mustang Evolution
Old 12-30-2012, 10:22 AM   #1
RUNNWLD's Avatar
Region: Utah
Transmission type
I have a 2004 gt what is my transmission type t5 or t45?
RUNNWLD is offline   Reply With Quote
Old 12-30-2012, 11:17 AM   #2
Mathew r Wright's Avatar
Neither one it's a tremec t3650...
Mathew r Wright is offline   Reply With Quote
Old 12-30-2012, 11:17 AM   #3
AgentOrange's Avatar
TR3650
AgentOrange is offline   Reply With Quote
Old 12-30-2012, 11:18 AM   #4
Originally Posted by AgentOrange View Post
TR3650
Oh yah I forgot the R lol...
Old 12-30-2012, 11:19 AM   #5
We commented at basically the same time lol.
Old 12-30-2012, 11:21 AM   #6
Yah lol..
Old 12-30-2012, 12:18 PM   #7
JetLife 01GT's Avatar
T5 are pre 95. T45 are 96-01. Tr3650 are post late 01
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 12-30-2012, 12:24 PM   #8
1slosix's Avatar
and from personal experience with a 3650 on my old '04 GT...change the fluid...change it often..and always add in syncromesh....because the 2-3 issue is highly common on them
carving corners like a boss
Old 12-30-2012, 12:27 PM   #9
1996v6stang's Avatar
The only gear i have any issue with is downshifting into first. Whats synchro mesh?
1996v6stang is offline   Reply With Quote
Old 12-30-2012, 01:07 PM   #10
deadsp0t's Avatar
Fluid, when I used it it was a GM product.
That's unimpressive
Old 12-30-2012, 01:15 PM   #11
RUNNWLD's Avatar
Region: Utah
Thanks guys!!!!!!(:
Old 12-30-2012, 07:23 PM   #12
How often should tranny fluid be changed?
Old 12-30-2012, 09:32 PM   #13
RUNNWLD's Avatar
Region: Utah
Is royal purple a good brand to go with!! And what one should I get like it has the numbers and I don't know how to tell what I need? Like 5w 45 or what?
Old 12-30-2012, 09:41 PM   #14
1slosix's Avatar
still is...but it does wonders in a 3650. just swap a qrt of fluid with a qrt of mesh and it really helps come track time
50k miles is what i did on my last few cars....fluid is cheaper then a rebuild
Old 12-30-2012, 11:01 PM   #15
deadsp0t's Avatar
Had a 3550 in my 1st 95 and was my understanding it was the required fluid..
Mine was rough, didn't really like it. I've driven several 3650's and they seem a lot more user friendly, like a T5
That's unimpressive
Old 01-01-2013, 08:05 AM   #16
I use B&M trick shift in my 3650 and have no complaints.
Old 01-02-2013, 04:33 PM   #17
Foxone's Avatar
So I see that Pennsoil makes a synchromesh product, is this the same stuff? Can I mix that in with some royal purple?
Foxone is offline   Reply With Quote
Old 03-24-2013, 02:49 PM   #18
So my 2000 GT has the T45. I'm wanting to replace the tranny, what I want to know is if the TR3650 will fit and if so what changes must be made because I believe the TR3650 is hydraulic clutch and mine is cable clutch. Correct me if I'm wrong please.
Call me fez is offline   Reply With Quote
Old 03-24-2013, 03:28 PM   #19
v8pony's Avatar
I just swapped out Mobil 1 ATF I had in my 3650, with 3 quarts of Pennzoil syncromesh, I must say shifting is a bit better, but it's def a bit more noisy on the shifter
2002 5spd GT
Feb 2013 Mustang of the Month
Old 03-24-2013, 03:46 PM   #20
Originally Posted by Call me fez View Post
So my 2000 GT has the T45. I'm wanting to replace the tranny, what I want to know is if the TR3650 will fit and if so what changes must be made because I believe the TR3650 is hydraulic clutch and mine is cable clutch. Correct me I'm wrong please.
3650 in a New Edge is a cable as well. They went to hydro in the S197. Unbolt T45, bolt in 3650.
Old 03-24-2013, 10:44 PM   #21
What would you recommend I replace my T45 with?
Old 03-25-2013, 08:36 AM   #22
v8pony's Avatar
A built 3650 is the way to go IMO
2002 5spd GT
Old 03-25-2013, 11:03 AM   #23
What do you mean by "built"
Old 03-25-2013, 01:28 PM   #24
v8pony's Avatar
There's performance shops that will beef up your 3650 for ya, my buddy had his rebuilt and beefed up with a hardened 26 spline input shaft, upgraded brass syncros, face hardening gears, and better bearings, for under 2k..I believe it can now handle up to 600-700 HP no problem
2002 5spd GT
Old 03-25-2013, 01:38 PM   #25
Mile high JDF's Avatar
If you have the money laying around I would go with a TKO600 or a Viper spec T56. If not then a stock tranny should work fine. What are your plans for the car?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-25-2013, 02:08 PM   #26
v8pony's Avatar
TKO600 is def a bit pricey and still has its known problems along with the 3650
2002 5spd GT
Old 03-25-2013, 02:11 PM   #27
A friend of mine runs a TKO600 in his Factory Five coupe. Had nothing but good things to say about it
Old 03-25-2013, 03:16 PM   #28
I need a tranny to get my car going because the T45 just gave out, it's only running on the first two gears. But I want to replace it with one that isn't as problematic as the current tranny. As for money, this is the best time to do it because of income tax. My budget right now is at 3k. Would buying a 3650, and doing the built deal on it, be the best way to go? what do y'all think?
---------- Post added at 04:16 PM ---------- Previous post was at 04:12 PM ----------
If it really is only about 2k to get the built 3650 it would leave me some cash to get some other stuff done to the car.
Old 03-25-2013, 03:37 PM   #29
Is your car making crazy power or something?
Old 03-25-2013, 05:12 PM   #30
No, not yet at least. But I plan on hitting at least 500 HP before the end of the year. And since the tranny already needs replacing I might as well put one that will endure that much power.
12:12 AM
