Just my luck - Mustang Evolution
Old 12-30-2012, 06:13 PM   #1
Matticus's Avatar
Just my luck
Surely as soon as I decide to start selling my car, it has it's first real problem. It won't crank, attempts to turn over but won't crank. It has fuel, no CEL, battery and everything is fine. Would it be a better bet to assume fuel issue or spark issues first?
Matticus is offline   Reply With Quote
Old 12-30-2012, 06:17 PM   #2
maldog's Avatar
Region: Nevada
Three things the engine needs to run.... Fuel, Spark & Air. So you will have to start to trouble shoot and find out which one you're not getting, or not getting properly? Good luck!
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 12-30-2012, 06:55 PM   #3
schmitty426's Avatar
Sounds like a fuel pump
schmitty426 is offline   Reply With Quote
Old 12-30-2012, 07:30 PM   #4
Matticus's Avatar
That's what my friend thinks too. Just more $$$ down the drain I suppose, was saving to get a dent fixed.
Old 12-30-2012, 07:35 PM   #5
Top stang's Avatar
Mines doing the same thing. Just got a new battery and fixed that issue
Top stang is offline   Reply With Quote
Old 12-30-2012, 07:37 PM   #6
Yeah same thing happened to me it just wouldn't run for the life of it lol just kept churing lol if u want to really know if its your pump have a friend turn the key to the last setting and put your head near the tank and u should hear the fuel pump ring for about a second if it dose its not the pump and if no ring its the pump
Old 12-30-2012, 07:46 PM   #7
Matticus's Avatar
It's a semi new optima red top, the battery is good lol. To my knowledge it'll have to be spark or fuel related, or may be a sensor gone bad.
Old 12-30-2012, 07:47 PM   #8
Eturner's Avatar
If you can, run some trouble codes on it.
Old 12-30-2012, 07:49 PM   #9
Matticus's Avatar
I checked DTC's with my tuner and it didn't throw any, I don't have access to a diagnostic tester though.
Old 12-30-2012, 08:38 PM   #10
1996mustang's Avatar
Test for spark. Remove a cable or plug whichever applies and put in near a ground. If u have spark it will arc it to the ground ...... just make sure u arent touching anything groundish just in case it has a bad coil/ wire the one u choose to test for spark. Personal experience it will tingle quite a bit lol. For fuel use the test port. Use a small object to depress the schrader valve to see if there is fuel in the rail. Once no more fuel comes out turn the key to on w/o starting the car and check to see if u have fuel. Anything else besides those 2 can be timing or a crank or cam sensor gone bad.
---------- Post added at 10:38 PM ---------- Previous post was at 10:37 PM ----------
It may even be a simple fuse blown too
08:18 AM
