A heads question - Mustang Evolution
Old 12-31-2012, 10:52 AM   #1
Mustang_Madness's Avatar
A heads question
I am going to put in my head gaskets from AM soon because my cousin blew one while i was in Basic quite a while back. It apparently got oil and coolant in the cylinders. I new to know what I should do while im down there so its good to go when i put it back together. What things should i look out for? I have a 98 V8 4.6l. What should i do! Thanks!
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 12-31-2012, 02:26 PM   #2
Coreyw428's Avatar
Region: Arkansas
Was it drove for a while with the blown gasket? Or has it been setting for a while since it blew?
Coreyw428 is offline   Reply With Quote
Old 12-31-2012, 09:55 PM   #3
Only sitting and collecting dust for a few months
Old 12-31-2012, 10:05 PM   #4
Coreyw428's Avatar
Region: Arkansas
If it has been setting for a while with coolant in the cylinders or even just 1 cylinder, it is more than likey rusted out pretty bad and will need to be sent to a machine shop
Old 01-01-2013, 02:45 PM   #5
Alright. Thanks... I just want to get it up and running so in that case what do i need to do to make that happen? How do I drain the coolant out?
Old 01-01-2013, 03:12 PM   #6
Coreyw428's Avatar
Region: Arkansas
There should be a plug on the bottom of the radiator either on the driver side or the passenger side that you turn and it will drain the radiator out
Old 01-01-2013, 03:21 PM   #7
CodyNelson's Avatar
Region: West Virgina
Also, pop the lower hose off that is coming out of the motor. That will allow all the coolant that is in the block to drain as well. The hose comes out right beside your oil filter.
Old 01-01-2013, 05:38 PM   #8
Oh ok! Thanks! Ill do that first...
Old 01-01-2013, 05:45 PM   #9
CodyNelson's Avatar
No you want to do the radiator first. If not the radiator will also drain out the disconnected hose and you will make a big mess. (ask me how I know LOL)
Old 01-02-2013, 07:17 PM   #10
sally2002's Avatar
How do you know lol. Sorry had to
sally2002 is offline   Reply With Quote
Old 01-02-2013, 07:50 PM   #11
runvsofthisbull's Avatar
Might as well put a nicer intake manifold on it TB or plenum too. Just an idea.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 01-03-2013, 01:36 PM   #12
I have a bbk 75mm tb on it already. I also have the manifold that has the aluminum thermostat housing..
02:37 AM
