please help someone tell whats this noise - Mustang Evolution
Old 12-31-2012, 11:58 AM   #1
Vmcgrath's Avatar
So I crank my car up and it making this awful whining noise it loud when it idles get louder when I rev my engine and when I turn the steering wheel it get louder and also when hit the brakes please someone tell me what this is thanks
Here's the link to YouTube
Vmcgrath is offline   Reply With Quote
Old 12-31-2012, 12:01 PM   #2
03fastblack's Avatar
Is it coming through your speakers?
03fastblack is offline   Reply With Quote
Old 12-31-2012, 12:07 PM   #3
jdavis96gt's Avatar
Region: West Virgina
I'd say alternator bearing or idle pulley. It sounds like it need replaced asap. If its alt, check at night, I might see sparks. I had a Beretta that did that.
Old 12-31-2012, 12:09 PM   #4
02PONY's Avatar
+1
02PONY is offline   Reply With Quote
Old 12-31-2012, 12:25 PM   #5
Vmcgrath's Avatar
No not through my speakers
---------- Post added at 01:25 PM ---------- Previous post was at 01:23 PM ----------
I might just replace both it wouldn't hurt to replace it a 98
Old 12-31-2012, 12:26 PM   #6
jdavis96gt's Avatar
I wouldn't go on any long trips dude, that sounds really bad.
Old 12-31-2012, 12:37 PM   #7
Vmcgrath's Avatar
I had a video I tried to post it did you see it? And don't worry it just a project car for now fixing her up brining her back to life she just sit and I crank her up every now then
Old 12-31-2012, 12:48 PM   #8
Vmcgrath's Avatar
I uploaded the video to YouTube
Old 12-31-2012, 01:14 PM   #9
jdavis96gt's Avatar
Spray some wd40 on idle pulley and see if that works. I think its alt bearing but idle pulley cheaper.
You could take your belt off and turn by hand. You should be able to tell if its turning smoothly or not.
Old 12-31-2012, 06:36 PM   #10
Mathew r Wright's Avatar
Kinda sounds like power steering to me but I dont know
Mathew r Wright is offline   Reply With Quote
Old 12-31-2012, 06:57 PM   #11
MedicDave's Avatar
That's power steering pump for sure, check your fluid level. If it is full then your pump may be craping out on you or you have a bad seal and fluid is leaking out, they will make noise when the fluid is low so check that first.
MedicDave is offline   Reply With Quote
Old 12-31-2012, 07:02 PM   #12
Medic dave I'm sorry but are you the same Dave on mustang medic lol???
Old 12-31-2012, 07:57 PM   #13
MedicDave's Avatar
I'm afraid not, I'm just Dave the medic lol.
Old 12-31-2012, 08:04 PM   #14
I kinda figured but I didn't hurt to ask. It's to bad I woulda asked for an autograph lol...
Old 12-31-2012, 08:17 PM   #15
Vmcgrath's Avatar
Well thanks medicdave I will look into that in the morning and prolly just going to go ahead a replace the alt too it wouldn't hurt it is a 98
Old 12-31-2012, 11:22 PM   #16
MedicDave's Avatar
Your welcome, I hope it works out for you. If that's not it then I'm not sure but it sounds like its running dry.
Old 01-01-2013, 02:02 AM   #17
Lorraine's driver
ab_mach1's Avatar
+1 on the alternator bearing or possibly the power steering pump. You could check your power steering fluid level and add if its low. Usually when it's the power steering pump, you can get the noise to change by turning the steering wheel while the car is idling in park (or neutral w/parking brake on for manual tranny). It will get louder as you turn the steering wheel, kinda like when you revved the engine.
Instagram: @ab_mach1
Old 01-01-2013, 06:43 AM   #18
buickregal79's Avatar
Quick way to tell take off the belt and spin everything by hand, if you feel one with a lot of slop or hard to turn like goes 30% around then gets tough theirs the winner.
Shutting off the thought process is not rejuvenating; the mind is like a car battery - it recharges by running.
buickregal79 is offline   Reply With Quote
Old 01-01-2013, 05:17 PM   #19
1996mustang's Avatar
I hears the video and im pretty sure ot sounds like the alternator diode is about to go. Also vaguely sounds like a power steering pump. And a small metallic grind like the water pump. If its the power steering pump it would make noise both reving the motor and while u turn the wheels on idle. But it sounds more like a alternator whine from my stand point
---------- Post added at 07:17 PM ---------- Previous post was at 07:15 PM ----------
I would do this too just to rule out any pulleys do them one by one like for example idler pulley spray on the bolt by the bearing and see if the sound went away. Then next the alterator...since its much easier to get to than the p/s pump lol then so on and so forth
Old 01-01-2013, 06:13 PM   #20
SoCalKev's Avatar
Send a message via Skype™ to SoCalKev
Power steering.
SoCalKev is offline   Reply With Quote
Old 01-01-2013, 07:12 PM   #21
Vmcgrath's Avatar
It will prolly be a weekend job it's the only time I have ill grab some wd40, power steering fluid and Power Steering Stop Leak maybe that will help
Thanks everyone for the help
Old 01-02-2013, 09:12 AM   #22
jdavis96gt's Avatar
Lucas stop squeal is pretty good. Worked for me but yours is WAY worse than mine. Good luck
Old 01-02-2013, 02:41 PM   #23
Vmcgrath's Avatar
My buddy and I was talking and he said it might be making the noise because I was low on transmission fluid and I said well that might be because I have a leak in a the transmission front pump
Old 01-02-2013, 02:50 PM   #24
fomoco4life's Avatar
Sounds definitely like power steering pump to me just turn the wheel and see if the noise changes ....if so, its gotta be it... if not alternator or water pump it has to be 1 of those 3 things.my $$$ on pwr steeringpump
---------- Post added at 01:50 PM ---------- Previous post was at 01:49 PM ----------
I wouldn't mess with any additives I would just change the pump... everytime you put those additives anywhere in your car they tend 2 f'*&* something up later down the road
Old 01-02-2013, 05:52 PM   #25
Vmcgrath's Avatar
I don't even know what the power steering pump looks like I couldn't even fine a video on how to change a pump
Old 01-02-2013, 08:35 PM   #26
Fluid goes rite n the top of it
Old 01-02-2013, 08:46 PM   #27
Vmcgrath's Avatar
So the power steering pump is above where you put the power steering fluid at?
Old 01-02-2013, 08:59 PM   #28
jdavis96gt's Avatar
No below it. I think its pulley closest to battery.
Alt pulley in middle,up top. Below that in center is water pump pulley.
Below water pulley is crank pulley. Those are pretty much straight up and down, right in the middle of motor. Now power steering is to the right of those. Your tensioner pulley is on the left of those. Hope that makes sense.
Might be diagram under your hood.
Old 01-02-2013, 09:04 PM   #29
Vmcgrath's Avatar
Yeahh it make since understand now, I'll still have to go out there and look at it but I know what your talking about
Does American muscle sell power steering pumps?
Old 01-02-2013, 09:10 PM   #30
most autoparts stores do not american muscle
however they may sell a delete kit lol. wouldnt suggest it unless u like to be like a honda with no a/c no p/s
Old 01-02-2013, 09:21 PM   #31
Vmcgrath's Avatar
Oh I figure they would sell like a high performance power steering pump heck the do everything else haha
Old 01-02-2013, 10:32 PM   #32
jdavis96gt's Avatar
CJ pony's sell em. They give discount too.
04:53 PM
