Installing my springs tomorrow - Mustang Evolution
Old 01-01-2013, 05:57 PM   #1
Doe_Rae_mi's Avatar
I'm lowering my car tomorrow finally...now it's going to be a 1.7 drop in front and 1.5 in back. Will I need caster camber plates!?
Old 01-01-2013, 06:04 PM   #2
Yes you will definetly need CC plates, you should also get an alignment soon after.
Old 01-01-2013, 06:05 PM   #3
Doe_Rae_mi's Avatar
Yea I'm getting them aligned next week.. But this cc plate thing is ganna drive me crazy lol
Old 01-01-2013, 06:07 PM   #4
Yea, but if you want any tread life on your tires you gotta get them lol.
Old 01-01-2013, 06:14 PM   #5
98vertgt's Avatar
You need them
98vertgt is offline   Reply With Quote
Old 01-01-2013, 06:15 PM   #6
JetLife 01GT's Avatar
You should be able to get by with only camber bolts. It's a much cheaper option you may want to consider
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 01-01-2013, 06:15 PM   #7
Doe_Rae_mi's Avatar
Are they easy to install? And which one will save me the most tread life...camber bolts or re aligned tires
Old 01-01-2013, 06:22 PM   #8
You will need camber bolts and an alignment. I was saying you may be able to use camber bolts instead of cc plates. An alignment will be necessary no matter what option you choose
2001 GT
Old 01-01-2013, 06:24 PM   #9
Doe_Rae_mi's Avatar
You will need camber bolts and a realignment. I was saying you may be able to use camber bolts instead of cc plates. An alignment will be necessary no matter what option you choose
Yea I was planning on realigning them ASAP. I already talked to the man and everything
Old 01-01-2013, 06:30 PM   #10
Well don't do it immediately. Give your springs a week or two to settle. Other wise your car will drop some more and mess up alignment. I'd say give ur springs atleast a week to settle but don't wait more than 2 weeks
2001 GT
Old 01-01-2013, 06:33 PM   #11
Doe_Rae_mi's Avatar
Okay sounds good...should I wait for them to settle for the camber bolts as well?
Old 01-01-2013, 06:41 PM   #12
1lowGT's Avatar
Eh I don't think you need them. Just get camber bolts and alignment.
Old 01-01-2013, 07:39 PM   #13
No, install bolts at the same time as springs. They should adjust the camber bolts for you when they align it.
2001 GT
Old 01-01-2013, 08:22 PM   #14
Doe_Rae_mi's Avatar
Would it be bad if I didn't install the bolts when I put my springs on? Bc I need to order them. Or could I get the man to install the camber bolts as he re aligns it? And would it be wise to buy some from autozone? Sorry for all the questions
Old 01-01-2013, 11:00 PM   #15
No you can install bolts whenever. You can have the mechanic install bolts when he aligns it. However it will likely cost extra money. Last time I was looking at camber bolts, pep boys sold some but they only gave you 1 degree of camber adjustment. The eibach bolts that AM sells give you an extra 1.75 degrees of adjustment. Idk about autozone ones but I would look at the amount of adjustment you get out of them. Eibach ones gave the most adjustment out of any that I saw
2001 GT
Old 01-01-2013, 11:24 PM   #16
Doe_Rae_mi's Avatar
Alright thank you for all your help man I appreciate it
Old 01-01-2013, 11:25 PM   #17
2001 GT
Old 01-02-2013, 12:56 AM   #18
02StangGT's Avatar
Where did you get your springs and how much?
02StangGT is offline   Reply With Quote
Old 01-02-2013, 01:06 AM   #19
Doe_Rae_mi's Avatar
Americanmuscle.com and for like 216 dollars including a sale and a 6 percent discount
Old 01-02-2013, 01:07 AM   #20
02StangGT's Avatar
Cool thanks
Old 01-02-2013, 01:10 AM   #21
1lowGT's Avatar
YouTube how to install camber bolts. It's literally so simple. Do it yourself to save money bro.
Old 01-02-2013, 01:26 AM   #22
Doe_Rae_mi's Avatar
Haha that's prolly what ima do.. Just scared that ima wait to long to put them on
Old 01-02-2013, 02:26 AM   #23
You can't really wait too long to put them in. Unless you align the car before you install them. You can always just get a second alignment as well. More money tho
2001 GT
Old 01-02-2013, 09:14 AM   #24
Doe_Rae_mi's Avatar
Just ordered the eibach camber bolts...thanks guys
---------- Post added at 11:14 AM ---------- Previous post was at 11:13 AM ----------
Just ordered the eibach camber bolts from am..thanks guys for all the help
Old 01-02-2013, 11:13 AM   #25
sixxerstang's Avatar
I wanna see pics when you're done, bud. Lol.
sixxerstang is offline   Reply With Quote
Old 01-02-2013, 11:49 AM   #26
Doe_Rae_mi's Avatar
Lol I will! Ima take a photoshoot
Old 01-02-2013, 11:50 AM   #27
Sweeeet. I'm hoping to get another photoshoot in of my car soon. Maybe after I get the decklid on it.
Old 01-02-2013, 01:15 PM   #28
if you install CC plates at the same time as the springs you can save yourself time/hassle as its mostly the same type of thing to do the plates later on.
I HIGHLY recommend maximum motorsports 4 bolt CC plates, they require drilling a 4th hole FYI but are very nice parts. Sometimes cheaper CC plates wont allow for the alignment to go back to stock spec as well while the MM Version the top plate flips side to side for more adjustment as needed.
You will need something if its camber bolts or plates it wont align at all with a 1.7 drop.
Old 01-02-2013, 05:36 PM   #29
Doe_Rae_mi's Avatar
Yea I ordered camber bolts today
06:27 AM
