fuel pump shutoff switch - Mustang Evolution
Old 01-02-2013, 07:48 PM   #1
Horseplay's Avatar
is it bad to use this as a security measure? like push the button in the night time and pushing it back on in the mornings before work? will doing this everynight harm my car ?
Low2v
Old 01-02-2013, 07:53 PM   #2
1996v6stang's Avatar
U talkin about in the trunk? Thought that was just a reset switch
1996v6stang is offline   Reply With Quote
Old 01-02-2013, 07:57 PM   #3
Horseplay's Avatar
i never used it but i heard it kills off the fuel so the engine wont start. i didnt know it was just a reset
Low2v
Old 01-02-2013, 08:13 PM   #4
schmitty426's Avatar
I think it works as both.. its like a kill switch pressed and its a reset when released I could be wrong though
schmitty426 is offline   Reply With Quote
Old 01-02-2013, 08:20 PM   #5
Horseplay's Avatar
it would be nice if i could use this as a security measure i just dont know if it will harm the engine
Low2v
Old 01-02-2013, 08:36 PM   #6
99redbeast's Avatar
I used to do that everyday when I had a 96 gt cuz somebody stole My keys and I was afraid they were gonna come back and steal the car, and I did that for like 6 months and it didn't hurt anything
99redbeast is offline   Reply With Quote
Old 01-02-2013, 08:37 PM   #7
Yeah idk it could be somewhat harmful like space in the fuel lines
Old 01-02-2013, 11:39 PM   #8
1slosix's Avatar
it'll be fine...the vehicle is shut off during the time you'll have the switch flipped so no worries...i make sure to flip the switch whenever i'm working anything fuel related
carving corners like a boss
Old 01-03-2013, 03:39 AM   #9
Horseplay's Avatar
ok thanks alot guys i appreciate the info ! do i just push the button while the car is off?
Low2v
Old 01-03-2013, 08:26 AM   #10
Isnt this just a button that you press and as soon as you release it re engages right? Or is it a switch? Just seems to me like its just a reset switch, not so much of a switch that turns off and on. I pressed mine once out of curiosity and was still able to turn my car on. Maybe im just confused about this whole thing or it malfunctioned. But i was still able to start my car right up still.
Old 01-03-2013, 09:00 AM   #11
cliffyk's Avatar
I do not know about the earlier models, however on the '99 through '04 the fuel cutoff switch is an inertia switch with a reset (only) button. Pressing the button will do nothing if the switch has not been activated by a jolt--I.e. in a crash.
You can make it activate by banging it with a rubber mallet...
Old 01-03-2013, 09:33 AM   #12
taylor98gt's Avatar
If you smack the switch the button will pop up and that is shut off, like cliffy said its a inertia switch, so if you wreck and it jars the switch it shuts off fuel, then you push it down to re set it
taylor98gt is offline   Reply With Quote
Old 01-03-2013, 11:43 AM   #13
Behind the switch there's a slot thats big enough for a flat head screwdriver than can go in and u can pop the switch back up
Old 01-03-2013, 11:45 AM   #14
Lmfao
Old 01-03-2013, 12:13 PM   #15
cliffyk's Avatar
I had forgotten about that; there are slots in the button shroud, on two sides, through which the button can be "popped" with an appropriate tool...
06:24 AM
