How to remove stock shifter knob from 1999 mustang gt manual? - Mustang Evolution
Old 08-18-2009, 07:00 PM   #1
i just want to take off the knob and replace it with a newer style one but i do not know how to take off the knob. thanks
tung is offline   Reply With Quote
Old 08-18-2009, 07:23 PM   #2
pretty sure you just twist it to to the left, theyre on really tight
tedmund is offline   Reply With Quote
Old 08-18-2009, 07:36 PM   #3
It should just unscrew.. If Not see if there is a small srew on the shifter knob
cristobal is offline   Reply With Quote
Old 08-18-2009, 08:00 PM   #4
If the older model stangs are like the new ones such as the 2002 then there will be an allen screw holding the shifter on. On the 2002 model it was located on the front side, towards the dash. After you unscrew this you should be able to pull the knob off with a twisting motion.
boothe is offline   Reply With Quote
1999 mustang
06:04 PM
